Shigshwa Posted September 24, 2013 Report Posted September 24, 2013 I used a clamp meter to measure the amp draw as I played sine waves. I noticed that my 3.5k drew 200A playing a 40 hz note, and 250 when playing a 50 hz note. Is this difference in amp draw due to requiring more power to play a higher note, or is this box related?
Omega5002 Posted September 24, 2013 Report Posted September 24, 2013 I guess what happens when you play way below tuning happens when you play way above tuning, happens to me as well. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
Shigshwa Posted September 24, 2013 Author Report Posted September 24, 2013 My box is tuned to 34hz. WinISD predicts the box's peak to be about 39hz. I wish I had the proper tools to measure things like impedance. So basically, when you play frequencies near tuning, the amp draw is the lowest since the port is doing most of the work and not the sub?
Krakin Posted September 24, 2013 Report Posted September 24, 2013 Would be interesting to see a test on this based off of tuning points. Same sub,amp,wire, ect... Just the only thing changing is the boxes tuned frequency. Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
Kyblack76 Posted September 24, 2013 Report Posted September 24, 2013 This is weird. Me and bighoss where just talking about this VERY issue. And, yep, its normal.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Swordlordboy1234 Posted September 24, 2013 Report Posted September 24, 2013 I noticed this too. Limited my dubstep playing for sure. I didn't like seeing low voltage My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Shigshwa Posted September 24, 2013 Author Report Posted September 24, 2013 I should have measured the draw at a different range of frequencies. I'm thinking that it's because more power is needed to generate the more oscillations in the same length of time, but if this were true, why does it take so little power to generate tones of much higher frequency?
bighossf150 Posted September 24, 2013 Report Posted September 24, 2013 This is weird. Me and bighoss where just talking about this VERY issue. And, yep, its normal.... Yep, Im tuned to 33 and drop .5v more on the higher notes than low notes Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
Rockford96 Posted September 24, 2013 Report Posted September 24, 2013 Ive noticed this on higher notes i get more drop.. My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
Kyblack76 Posted September 24, 2013 Report Posted September 24, 2013 My box is tuned to 34hz. WinISD predicts the box's peak to be about 39hz. I wish I had the proper tools to measure things like impedance. So basically, when you play frequencies near tuning, the amp draw is the lowest since the port is doing most of the work and not the sub? I think, rise also plays here. When you play close to tuning, impedance rises higher. You will have less rise, out of your enclosures range. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
