Best wood for enclosure build.. Not MDF
David Bailey
Like the title states, what is the best wood to build a box that is not MDF. Reason being, I think I am going to stain my box, so MDF wouldn't work anyway. I see a lot of people using Birch, so why, and what is a good size. Like 7 ply or more? Any input would be appreciated. Thanks y'all.
Did you get that scar tissue when you got your vagina installed?
KNOWLEDGE DESTROYS FEAR Measure twice, cut once
JVC touchscreen HU Mmats E600.4
Realm L56c Audiophile 6.5 comps up front JBL P963 rear deck PB RTA 112 trunk CE Auto Big 3 Mechman 240alt D'Amore VM-1
plywood has a lot of voids in the inner layers. There is plywood from Canada that you can get the has no voids at all. Use MDF and then Veneer it with wood. If you can use solid wood Maple makes good heavy boxes with no flex. When my bicep heals from surgery I am constructing box out of hard maple. 1.5 inches thick. Stay away from plywood! Also if you use veener make sure you use contact glue for high temps. Do not want it to delaminate in your vehicle. Journeyman Cabinet maker here that has his own woodshop.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
That sounds great and all, but using MDF and an overlay just seems like a lot of overkill, work and money. I like your idea though. I want my box to look like a nice cabinet, with detailed wood grain brought out by sanding and staining. Can't wait to see your when you get around to it.
maple is awesome! Smells great in the garage when I cut it up too. But a little pricey
I am only doing a box for two 12's, so if I measure twice and cut once, I can get away with 2 sheets total. I will look into maple. And I can do the port walls with a cheaper (yet good strong) wood, since they will never be seen.
The acoustics will be different between the two woods.
Not too sure how it will, or how much it will effect it.
Krakin's Home Dipole Project
Good point. I will use all the same, the port walls will be minimal wood anyway.
At my local home depot the only kind of birch ply wood they have is 3 ply. How does that compare/what's the difference when you add more layers?
Car: 2000 Honda CRV
Battery: XS Power D5100R
Alternator: Stock 90A
Head Unit: Pioneer DEH-X9500BHS
Front Speakers: Alpine Type S
Rear Speakers: JBL GTO 628's
Wires: All Knu 4g. Soon to be 0g. Big 3 in 0g
Volt Meter: SMD VM-1
Amps: Rockford Fosgate T400-2, T1000-1bdCP
Subs: 2 SSA XCON 15's Sealed
Tint: Privacy glass + 5% in the back and 25% in fronts
  • Who's Online   1 Member, 0 Anonymous, 732 Guests (See full list)
