16 volt systems
Guest DC Power Kyle
15.95 would spike to over 16v lots of times when going from full output to no output. Just FYI
AGM batts like to charge at a max of 2.4V per cell.
So a 14V batt would charge at 16.8V
and a 16V batt would charge at 19.2V to top off.
Most cars cannot handle this. You can use a step down and do a split voltage system with high volt batts and a 12V bank.
Or you can risk it, or even look up the manufacturers of each electrical component in the car and see if they have a max voltage rating.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
IMO its not worth the risk, you can screw stuff up in your ride. Mainly your computer and sensors. Invest in more alternator power (amperage) adn externally regulate to a safe peak charging rate.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
stick with 12 volt man by the time you deal with step downs and all that jazz its easiest. And the main question is will your amps be capable of handling 14v batts since they charge at 16 volt and will send allot of amps into protect.
  • Who's Online   0 Members, 0 Anonymous, 876 Guests (See full list)
