Hertz don't it Posted October 16, 2013 Report Posted October 16, 2013 I am wondering about setting up amps. I am planning on getting 4 15" Fi Q subs.. rms looks like 1500w per sub. I see 3 different options here: 1. Get 4 amps that put out 1500w rms @ 1 ohm ( one per each sub) 2. Get 2 amps that can do 3000w rms @ 1 ohm ( pair the subs up wired to 1 ohm) 3. Get an amp that can do 6000w rms for all of them. I am more leaning to the running 2 amps powering 2 subs each. The question I have is going with 4 amps vs 1 big one... is it the same amperage draw? Will it take the same amount of alts and extra batteries.. or would 4 me slight more efficient? Does it just make it much more complicated with 4 amps rather than 1 or 2? How many of you have tried both? Any problems with one way or the other? Any advice would be helpful.
hazestorm23 Posted October 16, 2013 Report Posted October 16, 2013 Getting one makes it very simple 4 is OK too but you have to set everything the same so that all subs get same amount of power if they are strappable then that's even better so you should decide what amp or amps first and then get the subs accordingly to what you want the final impedance on each amp .and about the amperage draw it depends on the amp itself so I would do some research on what your electrical can handle and see if you have to upgrade anything in your electrical because it does you no good to have a big amp or amps and your electrical not being able to handle them
bighossf150 Posted October 16, 2013 Report Posted October 16, 2013 1 6k would be cheaper that 2 3k's or 4 1500's Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
hazestorm23 Posted October 16, 2013 Report Posted October 16, 2013 And welcome to the forums got any ? On car audio problems I'm sure there is someone that has already been there and can help you. That's why I joined here
Kyblack76 Posted October 16, 2013 Report Posted October 16, 2013 Im not even gonna read all that. Fact is,.... multiples are PROVEN louder. Just is what it is. if I could re do what ive done........ id venture other wise. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
mikeg321 Posted October 16, 2013 Report Posted October 16, 2013 I believe 1 amp is more efficient than multiple amps. I'd personally do 2 3ks reason being if one of the amps take a shit you can wire your sub's to the remaining amp and still have some beat while you get the other amp repaired. Edit: while 1 amp may be more efficient, I can't say what would be louder 4 fully loaded Fi sp4 15's 2 Crescendo bc5500s Crescendo c1100.4 6 focal mids Vifa tweets 5 XS Power d3100's Pioneer avh-p4200dvd All crammed into a mustang. http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
Kyblack76 Posted October 16, 2013 Report Posted October 16, 2013 Smaller ones.. all day. I wish I would have.. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
TheMonolith2001 Posted October 17, 2013 Report Posted October 17, 2013 Im not even gonna read all that. Fact is,.... multiples are PROVEN louder. Just is what it is. if I could re do what ive done........ id venture other wise. I am not saying I don't believe you but how so? There must be some variable in the electrical system or the way the amps power supplies where built or something. Maybe lower distortion this way? The power being delivered to the subs must have been different for some reason in some way. It sounds like an outcome specific to certain amps but as a general rule of thumb its safer to go with one big one due to efficiency unless he has huge electrical.
Hertz don't it Posted October 17, 2013 Author Report Posted October 17, 2013 I am also curious as to why multi amps would work better. Does it draw over all less current from altinators? More power over all?
n8ball2013 Posted October 17, 2013 Report Posted October 17, 2013 My theory on this is that you split your load and impedence rise. Say with one amp you start at .5 and rise to 2. Well youre making less power. Now with 4 amps or two amps each amp will see half that rise. Youll make more power. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
