Punch P400.2 @ 2ohm mono?
DollarBill1
2 channel amplifiers see "half" the impedence when run in mono mode.
8 ohm mono is effectively 4 ohms.
4 ohm mono is effectively 2 ohms.
2 ohm mono is effectively 1 ohm.
These are the wiring options for your single D4 sub:
4 ohm stereo: 100w+100w
8 ohm mono (amp sees as 4 ohms): 400w
2 ohm mono (amp sees as 1 ohm): not recommended
Hammerdown... 1%
My sub is dual 4 ohm.
Rated Power: 100W x 2 @ 4-Ohms RMS; 200W x 2 @ 2-Ohms RMS; 400W x 1 @ 4-Ohms bridged
Wouldn't running it 8 ohm bridged be the same power as 4 ohm stereo which is 200W and is half the rated power that it would run at 4 ohm bridged?
Now I don't feel so dumb.
See post #3.
Amp/Sub not a good match bud. Best way to do it is to run a coil per channel and call it a day until you can get a better match one way or the other.
It will not like it
Not a good idea
I wouldn't try it
Where there's smoke there's fire
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Shouldn't that be 8ohm mono 200watts?
  • 100 watts RMS x 2 at 4 ohms (200 watts RMS x 2 at 2 ohms)
  • 400 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
Hammerdown... 1%
No, unless they wrote the 4 ohm bridged output wrong and meant 2 ohm bridged (effective).
Hammerdown... 1%
8ohm will be 200x1, same as the 4ohm stereo channels summed. 4ohm will be 400x1, same as 2ohm stereo CHs summed. Since he has dvc4, he can wire 8ohm mono, 200w, or on 1 2ohm stereo CH, also 200w. Those are his options for not running under impedance.
Team Flex Issues
Low tuning > God
2011 CALI AS1 STATE CHAMP
this sounds right to me.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
