CleanSierra Posted October 20, 2013 Report Posted October 20, 2013 I usually use body filler and feather it out, prime and paint. Here is a finished product with same method: Satin black Gloss black: Before Middle: End product: Im not the one you want to try to troll. Just a fyi for you.
Soccerballzs Posted October 20, 2013 Report Posted October 20, 2013 The issue is where an exposed cut edge is. The cut edge will soak up paint like no other[/quoteThat is why you need a professional sanding sealer. Even on exposed edges. You must sand with fine sand paper between coats also. May take more then 2 coats of sealer http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
pioneerforlife Posted October 20, 2013 Author Report Posted October 20, 2013 I usually use body filler and feather it out, prime and paint. Damn does that look good 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
CleanSierra Posted October 20, 2013 Report Posted October 20, 2013 I usually use body filler and feather it out, prime and paint.Damn does that look good Thank you. If you need any tips, I'll be happy to help. PM me if you want specifics. Im not the one you want to try to troll. Just a fyi for you.
knowledge Posted October 20, 2013 Report Posted October 20, 2013 throw the specifics here man REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
4bannger Posted April 1, 2014 Report Posted April 1, 2014 Body filler is a good idea. I'm gonna have to try that.
MoFatt0529 Posted April 14, 2014 Report Posted April 14, 2014 When I do a small setup I can get by with joint compound, the stuff you use on drywall, BUT instead of using bondo on the end grain of your mdf you can take wood glue and thin it out with water like 50:50, when you thin it out me wood soaks it up more and goes down inside of the wood, so that way when you do your final sand you dont sand your body filler back down to the wood grain and you arent left with and ugly spot on your finished box!
KickerKid58 Posted April 15, 2014 Report Posted April 15, 2014 I've noticed that a few good coats of primer goes a long way, especially with colors. I just used some old killz that was laying around and it worked great 06 Jeep Grand Cherokee 2 DC Level4 12" Soundstream TA1.3000d 4 RF Punch 6.5" Components 2 RF Punch 3.5" 2-ways RF Prime 400.4D XS Power XP950 +&-run of XScorpion 1/0 OFC My Civic Build
Ritch40 Posted June 1, 2014 Report Posted June 1, 2014 i have done more than my fair share of body and paint work over the years. personally, i'd try and talk you into spending just a little more money. to start off (like others have said) scuff sand the entire box and get any filler work done. then id lay down 3-4 coats of mar hyde 2k high build primer (or something similair). block that down good. then a coat of some sort of 2 part sealer primer. Then i would use either a 2 part enamel ( such as dupont Centari or one of the cheaper 2 part single stage urethane paints) the biggest reason i would suggest going this route is the fact your project will turn out better and stay looking nice for a lot longer. Sure it is a little more money,but, i do think you will thank yourself in the end.
Ritch40 Posted June 1, 2014 Report Posted June 1, 2014 another trick for sealing up end grain in to take a simple 2 part epoxy and (wearing gloves) work the epoxy into the end grain. it does take a little time to work it in there good, but, will do a wonderful job of sealing the end grain up.
