[fixed] Help! Mystery problem. I'm clueless
My guess is the amp even though you tried another one. You ruled out the h/u. Remote wire is iffy. Maybe try a 3rd amp if possible. Re check power and grounds again.
Just hooked up one of the amps to my shop PSU setup and it works perfectly. I'll move ground after work
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
This is why I asked if you replaced both amp/subs at the same time. The only thing really left is the wiring.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
my guess is your remote lead is enough to turn the amp on. but not really turn it on. meter the lead. does it give you the same results as the power lead? If not problme solved.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
That is a good thought N8 but wouldn't that be eliminated by jumping the connection?
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
I would think that if you did that already with a switch, you've re created your own remote, but if your'e still having the problems after that then it's more than just the remote wire. BTW, if not changing the head unit, I'd advise you running that switch off the ignition wire not the 12v constant just so you don't mistakenly leave it on and drain the battery.
Oh I know man I was just temporarily doing things to troubleshoot but thanks for the reminder
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
Well its fixed. I'm not 100% sure what it was, but I replaced RCA's, remote, power wire fuse, sub wiring, moved ground
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
Have you pulled HU to inspect everything.
truthsayer
My buddy called me because him amp shut off.
I installed this small system EXCEPT the h/u
http://www.stevemeadedesigns.com/board/topic/168025-05-s2000-single-12-all-fiberglass/
So I take a look at all connections
Power- good
Ground- good
Fuses- good
Remote- wire is good but will not turn on amp
run new remote, still no turn on
jump remote to power, amp turns on
install switch to control amp power
Amp is on, sub connections good, sub doesn't play but pulses every few seconds
check coils- good
New amp, same model, same pulse problem
New sub, different model, same pulse problem
New RCA, same pulse problem
Disconnect RCA, use adapter to play music from my phone through RCA, same pulse problem
With music playing and amp on, disconnect sub wires and reconnect, split second of normal level and then drop to low and pulse.
Confused. Discuss please.
Can you explain the switch you installed? Specifically, where is the power coming from? Still the HU?
Not sure if this has been asked, I did skim through responses but didn't read thoroughly, but did you measure the voltage of your remote turn on?
My first guess is that your HU isn't putting out enough voltage. It's putting out some obviously, but not enough would be my guess. Could also be a bad ground.
I would try (one more time, I know you already did this) jumping the turn on from the power. If all is good to go again, what I would do is:
  1. Tell your friend to get a new H.U.
  2. If he says no, then run the remote turn on from either the fuse box or a wire under the steering column, whatever is best in that vehicle.
  • Who's Online   0 Members, 0 Anonymous, 2819 Guests (See full list)
