Johnny Clark Sr. Posted November 15, 2013 Report Posted November 15, 2013 Taylor fade did a clamp on it awhile back. It put out right at 1500 If I remember right his exact words were "the pure 3000 is a descent 1500 watt amp" You are wrong buddy.
SoundStreamT5 Posted November 15, 2013 Report Posted November 15, 2013 If your running a fuse to your amp that could be a plosible reason for it cutting off, if you have a fuse hooked up try running a wire WITH OUT a fuse and try that. ALOT of people are having thier amps cut off and they spend big $$ to replace something that wasnt needed. If I where you I wouldnt even have a fuse running to the amp, just by me removing fuses from my amps I bumped up +2DB
soundstream15 Posted November 15, 2013 Author Report Posted November 15, 2013 I do not fuse between rear battery and amp.. I doubt removing a fuse gave you that much of a gain tho..
will77530 Posted November 15, 2013 Report Posted November 15, 2013 fuck it im sold, im selling my dc and alpine and buying pure 3k can you reccomend me some subwoofers i want the slaps in my trunk
JesseyMclame Posted November 15, 2013 Report Posted November 15, 2013 I do not fuse between rear battery and amp.. I doubt removing a fuse gave you that much of a gain tho.. You should fuse between rear batt and amp. Protect your next investment. I would say only time NOT to fuse, is if you're doing PURE spl comp's with like a burp box or something. Don't listen to that guy up there lol Current setup in my 96 Hoe Hu - Pioneer DEH-80prs. Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets) Batts - 4 91ah rear batts, 50ah batt up front. Subs - 2 Crossfire XSv2 18's Alt - Singer 330A Front stage - Random JL & Eclipse mids, Eclipse tweets
Sergeant_Skyrim Posted November 15, 2013 Report Posted November 15, 2013 If your running a fuse to your amp that could be a plosible reason for it cutting off, if you have a fuse hooked up try running a wire WITH OUT a fuse and try that. ALOT of people are having thier amps cut off and they spend big $$ to replace something that wasnt needed. If I where you I wouldnt even have a fuse running to the amp, just by me removing fuses from my amps I bumped up +2DB Finally some good advice in this thread! Since you're having amp issues you should just get rid of the fuses and hope for a fire so you can collect some insurance money and rebuild even bigger! Build in progress
Johnny Clark Sr. Posted November 15, 2013 Report Posted November 15, 2013 Batts are close to dead. Charge them return with results.. Too much voltage drop at 1 ohm on that amp
rockFord_Expedition Posted November 15, 2013 Report Posted November 15, 2013 If your running a fuse to your amp that could be a plosible reason for it cutting off, if you have a fuse hooked up try running a wire WITH OUT a fuse and try that. ALOT of people are having thier amps cut off and they spend big $$ to replace something that wasnt needed. If I where you I wouldnt even have a fuse running to the amp, just by me removing fuses from my amps I bumped up +2DB Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
ToNasty Posted November 15, 2013 Report Posted November 15, 2013 Taylor fade did a clamp on it awhile back. It put out right at 1500 If I remember right his exact words were "the pure 3000 is a descent 1500 watt amp" You are wrong buddy. We'll prove me wrong "buddy". I never said I was 100%posative. Prove me wrong ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
