DubNDodge Posted November 15, 2013 Report Posted November 15, 2013 Even if you drop 0.1v you can notice your lights dimming. The only way to fix this headlight dimming completely is to have hid lights. The ballast will output a constant voltage. Did you sand your grounds? Did you buy you alternator off of ebay, tenny or iragi? '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
walwalka Posted November 15, 2013 Report Posted November 15, 2013 Yes it would, you will need more battery reserve and preferably AGM power cells. If you could find the brand of the alternator, that would help too! 2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
raolito1980 Posted November 15, 2013 Report Posted November 15, 2013 Yes the 0 awg ofc will support the 2 amps. 2012 GMC SIerra CC System Build Headunit--Stock Sub Amp--DC 2.0k Subs--2-SA8v2's Enclosure--Need one made!! Highs Amp--Sundown SAX-100.4 Front Highs--Rockford Fosgate T2652-S Rear--Sundown Neo Pro 6.5 XS Power D2400--XS D3400 No Big Three yet! http://www.youtube.c...ser/raolito1980
Alouie Posted November 15, 2013 Author Report Posted November 15, 2013 The volt meter in my dash was dropping bad also. That's why I started asking questions. I don't want to low volt my amp.
Skullz Posted November 15, 2013 Report Posted November 15, 2013 Another option is to run 8awg to each headlight with a relay next to each lamp to bypass the lengthy run into the cars headlight switch and back out. EDIT: The run to each light is from the battery to the relay. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Alouie Posted November 15, 2013 Author Report Posted November 15, 2013 Thank you guys for helping me work out my issues.
graham0599 Posted November 15, 2013 Report Posted November 15, 2013 More then likely it's the grounds My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678
snafu Posted November 15, 2013 Report Posted November 15, 2013 Voltage drop is a function of how car audio amplifiers consume current. A quality 1 Farad capacitor located within 18" of your amplifier will likely eliminate it. Tony Candela - SMD Sales & Marketing Email me at [email protected] to learn about becoming an SMD Partner!
ric006 Posted November 15, 2013 Report Posted November 15, 2013 RF amps are power hungry, did you remove your original calbes on big 3 or add on not to mention do you have a battery in the back
Daniel Harbeson Posted November 15, 2013 Report Posted November 15, 2013 what size fuse do you have in the line from the batt to amp?
