best cheap subs.... best cheap high excursion sub?
exxxtrem
Why not have one big port? instead of wasting time and wood making a bunch of smaller ones?
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Im done for awhile. I apreciate the rocommended namebrands to ch eck out. This nit pickin shit is a waist of time.
Do I said 1.75 oer sub and .25 for port. Per sub. So my ports are 2x12x16
Now lets add the mdf thickness
2.75x13.5x15.25
.32 cu ft per sub
why not just make one big port instead of 6 little ones?
nit picking because we're trying to help you not make a big mistake.
Im gonna only do 1 big slot port.
Just threw a simp l e number out there
doing a one port per sub example is not simple. its more confusing
Do not buy planet audio/hifonics/boss ect. You are NOT getting your money worth.
Bad efficiency
More heat
More current draw
Bad thermal compound on the mosfets
Cheap mosfets
Cheap caps
Easy as shit to clip your subs
Easy as shit to go up in smoke < I have seen it happen many times Sewell as others on this forum
Not so vibration resistant
You will be lucky to get 80% rated power AT 5>%thd and I mean damn lucky!
If you buy a soundqubed it will surly outlast a shit ton of woofers and it will be more friendly on your alternator.
But if you buy boss/planet audio/audiopipe/hifonics it is a damn near 50/50 chance your amp will go before you swap another sub. And I am speaking from 10 years/8hrs a day/6 days a week experience
you could try Obsdiain audio subs highest priced woofer is $190 and thats for the 18inch. sundown audio = Obsidain audio. the obsidain 18s I have now are louder then my old system which was 2 jl audio 13w7. and the obsidains are running on half the power www.obsidiancaraudio.com
Ok. So im gonna make a comment that is gonna start shit.
What are we basing a good sub amp by?
I will say a cheaper amp can sound muddy not as crisp... affects your highs way more than subs.
If we wanted perfect sound wed still use class ab amps on bass.. but we were all good with losing clarity to pick up that aditional class d wattage..
So I ask the famous question where do we draw the line good and bad.
Will a cheap amp with the gains down a little as a good amp with gain up.. sure
I run all class D and I have a super clear system times have changed bro
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
