Dc build and Audioque build
Impalalpine
How would you guys rate the quality of the components used,board securing to chassis. Vibration resistance, and reliability. Any and all information you guys could give would be appreciated.
Two amps such as a DC 3.5k and the SQ3500.1 I want to know the differences between the overall build quality between the two. I'm not asking which one is better and I know they are built in the same build house, again I'm interested in the construction of them and differences they have.
They are very closely priced
Thank you all
Build's consist of:
2004 Chevy Impala :
Pioneer--------------------- DEH-X8600bs Soundqubed/AQ------ Q4-120
Rockford Fosgate---- Punch-500.4
Soundqubed/AQ----- Q1-3500D.1 Alpine----------------- 6.5's & 6x9's
Subs: TBA All Knukonceptz and SHCA wire and rca's
Home Music Setup
(4) Soundqubed HDS200 15's in two separate 15.5 cubic foot enclosures tuned to 31 hrz --- XM radio hardwire
Updates coming all the time on both builds
n8ball2013
"bullshit. Everything fits. If you cut enough."
I currently own an Aq2200 and am looking at a DC 5k. I like the construction of both. Heard both and its all preference.
05 Escape
2 Ascendant Audiio Mayhem 15s dual 1
Populus Audio 6500 (the only one around )
1/0 SHCA OFC
XS 3400 under the Hood
XS 3100s in the rear X2
Pioneer 80 Prs
Pac
Prv mids and highs
2 8s per door 1 tweet
im more concerned with how the board is secured to the chassis of the amp. its qualitys of capaciters and mofsets used in the two brands. basically which one is built better. The overall quality of the build.
Build's consist of:
2004 Chevy Impala :
Home Music Setup
n8ball2013
You realize that the SQ3500 is a 4200w amp right?
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
yes, but If there were to be something to offset the price diffrence between the two( such as improved build quality) that would justify the price jump. that is the kind of information I am looking for right now
Build's consist of:
2004 Chevy Impala :
Home Music Setup
n8ball2013
DC uses higher quality internals that will last longer and also they will not protect at super low ohm loads.
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
I think I disagree with this. I'm not saying either amp is better than the other but how do you know that ?
From talking to a couple different amp repair companies when I was looking at possibly buying a couple amps that were blown from user error. Also I am not aware of anybody that can say they run an aq amp less than half ohm daily for a year without an issue. Keep in mind I run a aq amp and do not have a problem with them, but I can tell you in my opinion my current 2200 seems to be very power hungry.
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
