1 run of 1/0 or 2 runs of 1/0 - 2 batteries & aftermarket alternator
I have a stock battery up front in the engine compartment and a CRESCENDO LOGIC F-31HP AGM POWERCELL in the back. I will eventually replace the stock alternator with a high output alternator either mechman or dc power but which ever one would be about 250A max; idling around 180-200A. I was planning on running one run of 1/0 from the battery up front to the battery in the back (+ to + and - to -). But after doing some looking and reading around, I feel like I'm on the edge of the 1/0 amperage capacity. Or am I reading the chart or thinking about this all wrong?62425d1235669252-wire-gauge-ampacity-tab
The length of the run will be somewhere between 12'-20'. I know, it is a big range, but I'm trying to play it safe by overestimating.
QUESTION: Am I safe with the one run of 1/0 or should I have another positive to positive 1/0 wire or also a wire from the back battery negative to the chassis also or one 2/0 wire, or what? I want to hear everyone's thoughts and suggestions! Oh, and what size of fuses (2 of them; one close to each battery, right?) should I get for the positive wire?
TWO 1/0 is fine, one 2/0 is good also. you might... get away with one rune of 1/0...? the fusing should match you total amperage that you are running. that chart looks good. i think you are lookin at that correct.
what kind of vehicle, amps are you running
this is somthing simple to try.
amps= volts/ohms
amps=watts/volts
amps=the square root of watts/ohms
03 s-10 owned since 35k now 150k
alpine type-s 6.5 comp
alpine type-e 10 ported fiberglass
jl 300/4 (dead)
jl500/1 (dead)
2007 Ford Fusion
I will be running about 2000W RMS for the audio system. That is about ~140A at 14.4V.
Ok, so two 1/0 runs of the positive to positive. Do I put a fuse on each end of BOTH runs (4 fuses total?) And then can I leave the negative to negative at one run of 1/0?
if your running 2k please dont do anything more than one run.....seriously. One pos. run and one neg run
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
let me ask what wire your using first?
Skyhigh wire
some batteries
good wire. one run will be more than enough.
Skyhigh wire
some batteries
  • Who's Online   0 Members, 0 Anonymous, 1342 Guests (See full list)
