Are wire lugs & fuses electrical bottlenecks?
That is what a good crimp looks like
you used to small of a die, but it works i guess.
the next size up doesn't make a good crimp
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
yeah, i bought a crimper, had metric dies so i had to do that with the 8ga ones. Wasn't trying to flame you, that crimp is fine.
The answer can be both yes and no depending on how much wire and the size of the wire, and as long as you properly terminate the wire with a crimper you shouldn't have any problems.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Combining different metals will cause a voltage drop, small, but a voltage drop. This is normal and is how thermocouples function as an example.
Fuses are thermal devices and will also cause a voltage drop, again small, but there nonetheless.
When done properly there will be inherent voltage drops, but they should not affect a properly designed system.
Those drawbacks are worth the safety and convenience factors.
As stated above, bad connections can cause massive voltage drops and resistance/heat issues which can even cause fires.
Those instances though should not be blamed on the crimps and fuses themselves but user error.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
Voltage drop occurs across any connection or termination, no matter how well it is done. If terminations and connections are done properly, the voltage drop is negligible. Same thing goes for fuses - the quality ones have negligible voltage drop across them. Using a bunch of cheap lugs, fuse holders, and fuses is an excellent way to handicap the performance of your system.
A quality DMM is a car audio enthusiast's BEST friend. Why is it that so few use them (correctly that is . . . )? You can quickly and easily measure voltage drop at any point in your electrical system. At the very least, put the red probe on the output stud of the alternator and the black probe on the power wire directly into your sub amp (yes, you need to use an extension). Crank the system. The reading on the meter shows the difference between the two. Factor that as a percentage. If it's greater than 3%, you've got work to do. Same exact thing can be done between the case of the alternator and the ground wire of the amp. A MIN/MAX scale is very useful here as the meter can record this data according to dynamics in the music, which sometimes isn't possible to see with the naked eye.
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
could we get a write up on this? Would be a real nice addition to the forum.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
got the electrical guru himself to chime in, thats some nice info. i didnt even know you could get extensions for dmms, though thinking back i suppose my friends o scope does have like 10ft long harness on it, where as my dmm's is like 2ft, lol
Just so that you guys know, I fully illustrate how to properly use a DMM in both of my books. If you want to know how to wield a DMM and:
- Know how to properly use it
- Know how to put the data you can obtain with it to work
- Be the EXPERT
- Make $$
Then you absolutely should consider the meager investment in the books. Automotive Wiring and Electrical Systems shows you how to USE the DMM with confidence. Automotive Electrical Performance Projects shows you how to use DMMs to analyze the performance of various circuits, including your charging system. You can read more about both books here - http://www.ceautoelectricsupply.com/wiringbooks.html
Keep in mind, these are award winning titles and my first book has sold approximately 25,000 copies to date!
  • Who's Online   0 Members, 0 Anonymous, 3448 Guests (See full list)
