Looking for Black Friday Deal, Little Help!!
orion very often home theatre systems have active subs which simply take a single rca out from the amp so adding your own bottom end shouldnt be a problem.
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
Thanks, been researching and I see that (in most cases). Gonna go ahead and just get a receiver for now and build off of it.
So if anyone has a recommendation, or one for sale, I am trying to find a good one for $200 or less.
SMD Super Seller
My Feedback Thread
what features do you want/need? Basic surround? DTS, 96/24 sound, HDMI ins and outs, bitsteaming?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Already stated Im new to his, all that stuff you posted is unknown to me. All I know is I want 5.1/5.2 with at least 100w x 5 at 8 ohms, and the ability to connect my flat screen and PS3 to it.
I'll buy speakers later and deal with sub setup last.
SMD Super Seller
My Feedback Thread
For home surround you need a receiver that has preouts for subs, center channel etc. if you are going to add amps to run these. I run Onkyo with pre-outs for all channels each channel has its own amp plus 31 band eq. My systems has 20 pieces not including speakers. 4 subs.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
All the receivers ive looked at are internally amped for 5 channels (center included) and have sub pre-outs, hence the 5.1 nomenclature. Thanks though.
SMD Super Seller
My Feedback Thread
The link you posted should be a great unit to build on for your purposes.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882105726
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
