DC Sound Lab
I have the 2 lvl 5 12s I have a box design wondering if is good enough will do no harm. These will be ran off a CT Sounds 7k. in a 2012 ford fusion trunk.
box is 39L x 16High x 19deep. (inches) tuned to 32hz, the volume of enclosure is 3.40cubicft.
port is 4in wide, 14.5 tall, 38.42 long.
will have a double baffle, 45's in corner and a bracing wall on in side.
any input would be appreciated.
Edited by mgameforever01
sorry its 3.4 after all the 45s and bracing, and sub displacement.
did you also subtract for the port ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Just make sure the way it's designed the motors won't be choking the air flow on the inside of the box. Can't remember who it was but somebody was saying they made that mistake when they did theirs. Ended up crumpling the cone or something like that. Basically make sure there's enough space around the motors for air to flow and you should be good if everything else checks out
so i decided to just go to Ram Designs and get a custom design, double baffle and the flush look. so im gonna scrap my other design for this and will be tuned for 33hz. I will paint it black with a green port or white idk yet. so thanks to Ryan for this design.
Doh
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
