Lowest/High frequency you've farted?
you guys probably like threaded rod for bracing.....
A nice strong shaft usually works. Wooden shaft. Not a fan of threaded rod. Too heavy and TSA bitches about it.
I hear the bigger the diameter the better…for bracing that is
09 Challenger R/T (Audio system under construction):
  • Pioneer AVH-X4500BT (PAC RP4CH11 harness)
  • (2) Sundown Audio SA-8v2 (inverted)
  • CT Sounds AT1400.1D
  • XS Power D3400
  • 40 sq ft. Audiotechnix deadener
  • 1/0 Audiotechnix wiring
  • stock Boston Acoustic 7 speaker amplified system (for now)
  • Sealed trunk enclosure
Build log:
http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/
TEAM GOAT
  • XS Power D3400
Build log:
TEAM GOAT
Anyone got advice on how to be more stable while I wire lower? My supply varies on when I eat Mexican... the other day after two bowls of queso, even the dogs left the room. But my scores were way different every Time. Some times my gf's ear o meter would give me 4/10 others would be 7.5/10. Im trying to hit 8's all day long.
What Dafuq did I just type?
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
you are all amateurs. i keep telling my mother she should open a school and hold classes for you fools.she makes the dishes in the hutch rattle more than my stereo does.
03 Santa Fe E A 200 amp alt,JVC AVX840,kenwood 6.5 fr speakers,eclipse 6.5 rears,mids/high amp XTA-2160, sub amp XTA-5000d,0 guage throughout,batts-front/1 batcap 2000,rear/ batcap4000,2 C&D Dynasty agms, subs 2 DC XL M1 15"s in a music box tuned to 28hz....for now.
It sounds like her surround and soft parts might be stretched.
What frequency does your house like? She just might be tuned high
Have her look into a recone
Rolex you sicken me.
Just let me finish my pie
~ Juice
