Anyone know the tuning of this pwk design?
harrypm82
So since he makes box designs for a living why would think that he would tell you the port dimensions and tuning for free? Also you should design a box for your build not just copy something for someone else's that may not suit your needs at all. If you really wanted that exact design though you could just plug the numbers into Torres and calculate port length and tuning your self.
This is the only info I have and Pete doesn't like to reply
I wouldnt answer either, its obvious that its not your design since you said this is all you had, if it was your design it would have about 7-10 other pictures, including a response graph, cut list, and internal pics of the enclosure.
Your trying to get info from him that someone paid for, and that person was not you. So why should he answer you and reply with tuning of a box that was most likely not designed for his car.
Pete's a bitch, and his designs are shit. Good enough for you?
Get a better design elsewhere.
His designs are usually not that bad, and way better then all these other "designers" that still live at home with mommy and daddy, dont have a job, let alone a car to put their bedroom systems in.
Normally his designs are of a flatter response not the loudest, but flat, as well its worth mentioning that you can only design so much from a vehicle you dont have in your possession prior to testing, or even getting your own exact measurements.
PS: Your a bitch too at times. :
PWK. LOL.
like that time my buddy spent $50 on a pwk design for 2 12's. was tuned to like 25hz with 1.25" wide ports. dual chamber.
  • Who's Online   0 Members, 0 Anonymous, 6313 Guests (See full list)
