Impala-Chasing a 50 on the TL-Build log (Rockford Fosgate,Soundqubed,Alpine,Sundown)
Tuned too low, but should sound good on music. In for results!
for X's? I thought they would go in the negatives. if any subs would.
Build's consist of:
2004 Chevy Impala :
Pioneer--------------------- DEH-X8600bs Soundqubed/AQ------ Q4-120
Rockford Fosgate---- Punch-500.4
Soundqubed/AQ----- Q1-3500D.1 Alpine----------------- 6.5's & 6x9's
Subs: TBA All Knukonceptz and SHCA wire and rca's
Home Music Setup
(4) Soundqubed HDS200 15's in two separate 15.5 cubic foot enclosures tuned to 31 hrz --- XM radio hardwire
Updates coming all the time on both builds
n8ball2013
"bullshit. Everything fits. If you cut enough."
Im going to try to fit a huge kinetic or D3100 in the factory spot under the hood. and then another kinetic in the trunk.
how do you like that 120.4? Im slacking pretty ridiculous on mid's and high's. Have you taken the back off of it? i would love to see what its like
Honestly its never seen power, due to me not getting my doors done. You have plans for a h/o alt?
It's like rubbing your wiener up against a sheep.
would you buy it again? I looove me some soundqubed/AQ
edit: yes eventually
Build's consist of:
2004 Chevy Impala :
Home Music Setup
n8ball2013
Excuse my wiring
Build's consist of:
2004 Chevy Impala :
Home Music Setup
n8ball2013
What's up with the 6x9 on the floor?
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
the human ear can only hear from roughly 20-20k hz. To get good numbers a low tuning will only make it a lot harder.
Oh and don't believe everything you read online, just because people say that sub can play into negative freq ( first I hear of -freq?) Doesn't mean shit. That's like me saying tipi vision is wrong and the.sky is purple.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
the negative herz thing was a joke. there is no such thing.
and the 6x9 is there cause its a tight squeeze to get it into the rear deck and im lazy
Build's consist of:
2004 Chevy Impala :
Home Music Setup
n8ball2013
You should be able to fit an xspower d3400 or kinetik hc2000 in the factory location without modification. I believe rob "thorshammer" wedged an hc2400 in his gp, exact same factory battery setup. Nightmareimpala did a dual xspower d3400 in his 05 impala after removing the factory air box and putting a shirt ram air intake in its place.
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
