XS Power
HELP-New XS battery low battery volt
I would take that ground out and do a single proper ground to said strut tower. Requires removing one of the outside bolts and boring out the terminal... Sanding and retightening.
Good luck sir.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Here's the issue with self tapping screws on thin sheet metal
It pulls up the metal it's attached to, lifting up the terminal so you only get contact around the inner ring of your terminal. See below
Black = sheet metal
Gray = self tapping screw
Red = ring terminal
See what happens? Poor contact area, source of resistance and voltage drop. Ideally, you want to ground to something fairly thick, such as a strut tower or frame. But if you need to ground to sheet metal, you should put washers on top of the ring terminal, and on the opposide side of the sheet metal, that way the terminal and metal are sandwitched between the washers, ensuring(insuring? don't kill me grammar Nazis :) ) that there is no metal deformation and as much contact area as possible
Black = sheet metal
Red = ring terminal
Wow awesome thanks man! Well now i got a good game plan for tomorrow. Before i pull out my meter and start shooting im gonna start off my changing my ground. If its still inop then i'll take the readings and see if i notice anything out of the ordinary.
OP...
Do you see why I said what I said about snow in my earlier post.
Awesome guy, my personal "go to" guy when I have electrical questions.
/thread
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
So I haven't touched my car yet but I've been thinking.since my batteries are wired in series that would make my system a 24 volt system. My alt would see the front battery fully charged what if I added a voltage regulator so when either battery loses voltage it'll direct the charge to the respective battery. What do you guys think?
Woahwoahwoahwoahwoah
Unhook your back battery NOW. Do it IMMEDIATELY
Wire in parallel, not series.
I refuse to believe they let you work on f16's.
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
Government work,.. he probably designed them....
take meatless friday off OP
The rest of us will keep the world spinning...
Edited by KyLar96
  • Who's Online   0 Members, 0 Anonymous, 223 Guests (See full list)
