Great Watt Per Dollar Amp
TZspeakersZac
Also, thanks for the explanation of the electrical and port bit. I always thought high AND low could cause "chuffing". I just try to hit as close to 36.5 m/s in the port as possible. I do have solid electrical. I just have managed to word about 11 posts like I have half a brain. Which isn't too far out of the realm of possibility...
Nah man, it's cuz of the bass.
you are almost at a dead short. No amp will play that low. You will still see your starting load the second your amps are turned on and at any point that they are at rest. I believe that on a certain part of the woofers throw it will also see the starting impedence. Impedence rise is not hte answer here. The lowest I've ever seen an amp turn on was an orion 2500d. at .175. And you had to roll into it very slowly. Burp only
Whats your electrical like.
If you do an aq3500 its
350 amps at 1 ohm
about 700 at .5 and climbinging steadily each time you cut your resistance. What do you think that will be like when you are that low? If you don't have the electrical for all your 5500s you dont have the electrical to try this either. You can pull the protect and that will guarantee that this thing roasts.
BTW Ive been working on my truck for 4 years. IT's still nto done. Some things are worth the wait.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Yeah... My wording throughout the post has been pretty shitty, to be honest... I'm not sure I understand the difference between the m1 and m1u.
Sorry if i came off as a cock. But, .. it happens a lot here.
So, ... I apologize also.
The B2's we run are the M1s .. 2 strapped at .5 nominal, we could not make it work.
Wired up, and the fuckers pound 2 lev 6m2's.
just what we found
Don't worry about it. I'm sure I came off like a cock too. Was really not tryina. Do you mean 2 of the m1s amp, or 2 of the m1 amp?
just what we found
We are strapped with 2 m1s amps to 2 level 6's
Electrical, as it stands, is out for repair. I still have 6 kinetik HC 2400's in, as well as an 1800. But I have 0 alts, so the truck is just sitting. I'm going to have 1-3 singer 350's depending on when the bracket gets in (triple alts on a TB 4.2l are a BITCH). Old was 2 mechman 250's, then 1, now none.
Note: once again I've fucked up. I am about to drop a 250 back in. It has been un-running for 2 days. Not gonna be sitting for more than another day or so.
Also to help a little more with port area, take these into consideration.
Maximum usable velocity varies with flare radius.
There is a limiting velocity for any given diameter port, regardless of flare radius.
Larger diameter ports have a higher usable velocity than smaller ports.
Port performance varies with frequency.
Krakin's Home Dipole Project
  • Who's Online   1 Member, 0 Anonymous, 2128 Guests (See full list)
