building an electrical for half ohm
Alright lady and gents. I got a mechman 320 on the way and hopefully afterwards some new sundown x 15s looking to run this ct 1400.1 At half ohm. Big three check upgraded stock batt check 800 cold cranking amps To be exact 1/0 going to amp check. Fans on the way. Any thing I should put in mind considering this?
2001 Dodge Ram Quad Cab.
Here is my experience with running a ct 1400@ .5 ohm. I have a hdc 3 12 dual 1ohm sub. My electrical is a duralast platinum gel battery, big 4 ( added ground) with 1/0 . 1/0 fro. Battery to amp 1/0 ground all with copper ring lugs. 180 amp dc alt. The amp never ever gets hot. Sub never ever gets hot. Voltage drop (toyota has a low charging voltage) at full tilt is from 13.7 to 13 .2.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Add a second battery. Other than that, you're good to go.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
Something small like an XS925 in the rear should be pretty much it to be perfectly safe.
Well I was considering a d2700 upfront then a 3100 in the tool box or in the cab. I just don't want to dip below 13v. I went overboard with the alt but its there for a future bigger build so.
IMO with you HO alt I think another battery is overkill but if you plan to go bigger in the near future then maybe. I have not seen below 13 with mine. I don't have the knowledge of others but have the exact amp and running the ohm load your talking about. All set with a DD 1
80prs
DC 180 alt
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
