bcbrassard Posted January 30, 2014 Report Share Posted January 30, 2014 Any ideas on how to make this enclosure better. I know rebuilding a box is the best option but since i just upgraded everything 2 weeks ago, iam not real excited to tear it down to build a new box. Box is 3.116929 cu ft with T1D212" = 2.808(- 2 4" aero ports 9.75" long) Tuned to 42 i believe. I havent calculated for port displacement. Box inside demension are 14.5H x 36.5W x 10.5D I was wondering if putting a T1D215" with a displacement of .547 cu ft would help lower the tuning. I know the box need rebuilt, just scrounging for a way to make it better. Anyone? Link to comment Share on other sites More sharing options...
ToNasty Posted January 30, 2014 Report Share Posted January 30, 2014 3 cubes seems a bit big for a single 12 ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers Link to comment Share on other sites More sharing options...
Guest Posted January 30, 2014 Report Share Posted January 30, 2014 you can invert the woofer for a tad lower tuning. will make the box a little bigger though. Link to comment Share on other sites More sharing options...
Tarball Posted January 30, 2014 Report Share Posted January 30, 2014 stack your ports on one side and move the sub over a bit to make room. Drop your net volume down a bit and tune lower. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
bcbrassard Posted January 30, 2014 Author Report Share Posted January 30, 2014 I must say i was kinda worried when i seen Kranny respond! lol So you dont thuink a T1D215 would shrink the box size to help lower tuning? I suck at the box concept i guess. I understand it to a point but lost as well! lol Link to comment Share on other sites More sharing options...
bcbrassard Posted January 30, 2014 Author Report Share Posted January 30, 2014 This is why i dont want to put it all out to rebuild box anytime soon. I know,I know. I f'ed up when i built it. Link to comment Share on other sites More sharing options...
gr8handogoatness Posted January 30, 2014 Report Share Posted January 30, 2014 You could put a whole bunch of bracing in there to effectively reduce the volume of the box. Your idea about getting a 15 would probably work too, they like bigger boxes. Link to comment Share on other sites More sharing options...
alaskanzx5 Posted January 30, 2014 Report Share Posted January 30, 2014 That's an obcon box right? Look like it at least. maybe block a port to lower tuning. Worth trying IMO. Those subs like around 2-2.75cuft. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
alaskanzx5 Posted January 30, 2014 Report Share Posted January 30, 2014 I don't think the 15 is really .5 cuft displacement. The t2 is only .17 and they are the same size just a few small differences giving the t2 a higher power handling. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
bcbrassard Posted January 30, 2014 Author Report Share Posted January 30, 2014 That's an obcon box right? Look like it at least. maybe block a port to lower tuning. Worth trying IMO. Those subs like around 2-2.75cuft. No i built it myself a couple years ago. I just didnt have the knowledge i do now and like i said i F'ed up and just exploring SMDs expert advice to a easier fix than rebuilding. The box actually sounds pretty good for the music i like, i just know its missing the lows it could produce. Link to comment Share on other sites More sharing options...
