Can i make this enclosure better? Help?
bcbrassard
Any ideas on how to make this enclosure better. I know rebuilding a box is the best option but since i just upgraded everything 2 weeks ago, iam not real excited to tear it down to build a new box.
Box is 3.116929 cu ft with T1D212" = 2.808(- 2 4" aero ports 9.75" long) Tuned to 42 i believe.
I havent calculated for port displacement. Box inside demension are 14.5H x 36.5W x 10.5D
I was wondering if putting a T1D215" with a displacement of .547 cu ft would help lower the tuning.
I know the box need rebuilt, just scrounging for a way to make it better.
Anyone?
stack your ports on one side and move the sub over a bit to make room. Drop your net volume down a bit and tune lower.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I must say i was kinda worried when i seen Kranny respond! lol So you dont thuink a T1D215 would shrink the box size to help lower tuning? I suck at the box concept i guess. I understand it to a point but lost as well! lol
That's an obcon box right? Look like it at least. maybe block a port to lower tuning. Worth trying IMO. Those subs like around 2-2.75cuft.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I don't think the 15 is really .5 cuft displacement. The t2 is only .17 and they are the same size just a few small differences giving the t2 a higher power handling.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
No i built it myself a couple years ago. I just didnt have the knowledge i do now and like i said i F'ed up and just exploring SMDs expert advice to a easier fix than rebuilding. The box actually sounds pretty good for the music i like, i just know its missing the lows it could produce.
