So my teg has a prelude motor and it vibrates at idle pretty bad it's a 5 spd I've been told the only thing I can do is put a smaller motor back in it originally a dc2 gsr now also has a h23 trans and different motor mounts so the mirror will fit any tips?
softer motor mounts will help with vibration. but 4 bangers in general aren't very smooth motors. shit i can feel vibration through my steering wheel on startup of my brand new car LOL.
Honda engines are notorious for having low idle or vibration. They say that Seafoam helps a lot with it....
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
New motor mounts, something made for comfort. Hell my volvo shakes the mirrors at long stoplights from the naturr of the 4 cylinder idle. Turn the radio up :)
Check and make sure the balance shafts are properly aligned or if there's even a belt on them.....if you can live with it, no belt on the balance shafts does give you a rough idle but you gain a few hp and motor revs alot faster...had a fully built jdm h22a with h23 crank in a gutted 94 2 door accord about 8years ago... 220whp and 350ish whp on the bottle
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
H22's are powerhouse blocks with a ton of potential
Team MaxRetribution
Si Vis Pacem Parabellum
Seems a bit low...They are 200hp factory motors
Team MaxRetribution
