DC AUDIO 10K amp is it a good amp
letmeplaycoach
Does a bear use a rabbit to wipe his arse? Awesome amp awesome power on 12v
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
IDK I have never ran one but it seems like lots of people say good things about them.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
The 10k is the most powerful 12v amp I have had on the dyno to date. At 14.4v I have seen about 10500w certified at 1Ω and 9300w at 12.95v and 1Ω. If you have any questions about it, send me a message and I will be glad to help you out.
There you go. That's some big power.
80prs
DC 180 alt
  • Who's Online   0 Members, 0 Anonymous, 636 Guests (See full list)
