What Causes an Overboost Condition?
I didn't read the thread, so sorry if these have been already mentioned. I just took a quick look at the thread title..
Did you check your BOV or BPV?
Is your waste gate internal or external? Internal wastegates seem to be more prone (with us at least) to cause over boosting.
I'm more familiar with turbos, so these may not apply to SC'd cars.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
The blow-off valve works different on a s/c engine than a turbo'd one.
Really, the only thing that can cause overboost is a clog in the exhaust.
Could be an exhaust valve stuck shut, but that would introduce other factors.
SMD Super Seller
My Feedback Thread
Dont know that it applies since the seafoam was introduced through the tank but if you suck seafoam though an intake vacuum line (to clear the carbon out of intake system) it will make your exhaust thick as fuck and you have to keep the idle up or it will die. Seafoam maybe making thicker exhaust? Or it bumped your octane up enough your timing got advanced enough to dumo unburmt fuel into your exhaust
Idk im just spitballing
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
Seafoam only went in the gas tank. It does not affect octane.
However, I wonder if it broke down any gunk in my already broken head gaskets, causing a full-on leak.
Seafoam doesnt increase octane? I thought it was considered an octane booster. And the head gasket might ne a good guess.
Betting on that exhaust valve issue. Maybe not stuck but surely fucked up.
It does not. Its a detergent, thats all.
But if I had a small headgasket crack, that fixed itself through expansion and carbon in the gap, then the Seafoam could have theoretically broke down that carbon (or other shit), causing the head gasket to fail completely.
SMD Super Seller
My Feedback Thread
You have a fucked exhaust valve, imo. Cats don't plug that quick. It takes a year of a 10:1 AFR to plug a modern cat, at least.
I should ask, is this a screw, roots, or centrifugal?
I've seen SeaFoam type shit ruin the teflons on a roots blower. Teflon breaks, into the cylinder, then the ex. valve catches it in the seat, and bends the stem/sticks the valve.
Run a leakdown and compression check. I'm willing to bet this is something really bad, sorry.
UNLESS... Maybe the seafoam ate an injector seal, plugged it partially, and detonated the shit out of a cylinder.
Can you see duty cycle with your ecu?
Check your valve springs.
Also, for this application an old school spark plug is best.
My 4000hp Fuel Altered (Top Alcohol engine) used $1.27 Autolites or NGK TR's.
If you look at any race car, they have old school plugs. I have tested every plug on Earth damn near, on the dyno, and a simple plug makes more power every time, especially on a blower motor.
The rest is marketing.
Also, I'd advise against fuel additives on a blower motor, there is ethanol in the fuel anyways. You can run 1oz of acetone per 10gal if you want, usually good for 3hp.
