2006 Nissan Titan Build, 15" DSS Ethos has arrived
Today was a pretty successful day. I thought I would get both the big 3 and amp power and ground ran but I ran out of solder. This sky high cable is awesome stuff to work with. I got the amp power and ground wire all run and also the big 3. I ran out of solder when I got to the fuse to battery cable section. So hopefully I will get time to buy some more solder tomorrow. I also redid my grounding point for my amp. I did a run from the engine to ground, battery to ground, alternator to battery and alternator to ground. I would have got more pictures but I was running out of time so I just kept chugging along. I also relocated my junction box for all my cold weather heaters. I originally had it right by the battery and it kept getting in the way.
Amp wiring before
After
Seat in
My old lightening audio 4 gauge compared to sky high 1/0
Some pics of the upgraded power and grounds and upgraded terminals
New junction box location
From left to right sky high 1/0, lightening audio 4 gauge, factory ground(used to ground the battery and engine block with this tiny thing)
  • 1 month later...
Well after a lot of back and forth I finally decided on a dss ethos 15". My main reason was do to the ethos liking small enclosures. My finally design ended up being 3.35 cu ft net with 58.5 in2 of port tuned to 32 hz. After talking with dss I felt very comfortable with this design, so I started to build it. I got an email saying it shipped so I hope to have it within the next week. Anyways onto the pics.
3ade3990-250d-4bc0-b2a6-19b0ba223d32_zps
Started sanding down the body filler but had to stop since not everyone is on night shift like me. Lol. Also installed some terminals on my sky high 8 gauge speaker wire.
Looking good.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Liking it
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
Nice. So where will the 15" box sit in the cab? are you losing your whole back seat?
2000 Jeep Cherokee
15" Alpine Type R box build coming soon!
Looking good.
Liking it
Thanks guys.
It is going where the 40 split is. So I will only be losing 1 seat and it will be removable if I need the extra seat. The sub will be firing into the back of the drivers seat and the port will be firing up.
Got all the body work done and did a test fit. I have about 4" of clearance to the back of the seat where the sub will mount. Only thing I found that I dislike is that the floor has a slight slant to it. I didn't realize this when I started. It's really not a big deal, but the enclosure doesn't sit as close to the folded up seat as I wanted. Now I just have to figure out a way to secure it. Not sure how I will go about doing this. I was thinking about making a mount to bolt it to the rear seat frame.
you have good woodworking skills!!! beginner or not, your a natural!!!!
2011 Nissan Altima aka Red Ruby
HEADUNIT: Pioneer AVH X2700BS
ELECTRICAL:
-Singer 230a
-Northstar gr34
-(2) Northstar SMS220 w/ Custom Terminals from 12V Metalworkz
-100% Welding Cable
FRONT STAGE:
-(2 Sets) Hertz HSK165
-Hertz HSK130
-Ampere Audio 125.4
SUB STAGE:
-(3) Sundown Audio SA REV2 12's
-Ampere Audio 3800.1 V2
MISC (NON AUDIO RELATED):
-Interior & Exterior Lights LED
-Gloss Black Roof (PAINTED)
-15% Front, 5% Rear Tint
-Roof Spoiler
-20" TSW Snettertons (20x8.5 front, 20x10 rear)
-Custom Projector Retrofit (FX-R 3.0, 6.5k HID, Morimoto Mini H1 (faux projector), Quad Starry Night Halos) ----- COMING SOON!!
-Aftermarket Fog Lights
-Custom Painted Engine Covers
My Build Log: http://www.stevemeadedesigns.com/board/topic/169869-woods-2011-altima-aka-red-ruby-new-video-more-updates/page-109
Retrofit Build Log: http://www.stevemeadedesigns.com/board/topic/185787-hid-projector-retrofitting-diy-by-wood/#entry2765346
heard a ton of good stuff about those Ethos subs. Tuned in for the results.
