No airflow from port - driving me crazy
DynamikT
I have 2 power acoustic mofo 12's in a 3.9 cubic box.. I can see them both move alot but hardly any volume is coming out of them? When i just have one hooked up it sounds MUCH louder than both of them, ive done the wiring correct, my amplifier is underpowering them but even so when they are moving this much, i know it should be alot louder. Below are my box specs...
I read somewhere there is a possibility of a box being too small so then a push/pull config has to be done where one sub is flipped, is this my only solution in this particular box? Thanks.
Sounds like one of then is out of phase
What he said, swap the pos and neg on one of the subs
Brandon
2000 Furd Ranger supercab 4x4
System:
welding wire throughout the truck
USalts 390amp Hairpin
Juicebox in stock location
8 Banks of maxwell supercaps
2 American Bass Vfl 1100.1 wired to .35 each
2 Fi Audio Sp4 18's ( the DD sc 9918's smoked)
Pioneer radio with Soundstream PA mids Powered by a nice sized soundstream 2 channel
It's pronounced (dain-ja rain-ja) :ph34r:
2001 2 door focus
1 DD9918 SC
update: Problem solved, thanks again. i cant seem to find an explanation on the internet on why this happens / out of phase situation though? if someone can mention, would be great. they are both dual 2 ohm subs wired as 4 ohm each.
The port area may also be to large. Even though the enclosure is "tuned" to 30 hz, if the port isnt the proper size according to the drivers, such problems will arise.
Aviod enclosure calculators that dont take the driver into its calcualtions.
Also, what kind of amplfier do you have?
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
move the port
09 Challenger R/T (Audio system under construction):
  • Pioneer AVH-X4500BT (PAC RP4CH11 harness)
  • (2) Sundown Audio SA-8v2 (inverted)
  • CT Sounds AT1400.1D
  • XS Power D3400
  • 40 sq ft. Audiotechnix deadener
  • 1/0 Audiotechnix wiring
  • stock Boston Acoustic 7 speaker amplified system (for now)
  • Sealed trunk enclosure
Build log:
http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/
TEAM GOAT
While the needed port area for the subs should be 49 in2 at 30hz, having 36 inches will increase velocity of the air.
OP if you are not having air flow, then you most likely have one of the subwoofers wired backwards causing the phases to be 180 degrees away from each other.
This means that when one subwoofer has the cone being pushed outwards the other is being pushed in, causing the pressure to be canceled out.
I noticed you said "push/pull" configuration in the beginning, this would be wiring out of phase. You need both of the cones to be moving in the same direction at the same time.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Ive actually made a box for these exact woofers
I gave them 2 cuft each after all displacements
but I gave them 64 sq of port area
they loved it
kicker u lite app on your phone shows wiring diagrams to help
asks what coils are on the woofer/s and what resistance you need to the amp
CAR AUDIO JUNKIE
  • Who's Online   0 Members, 0 Anonymous, 2631 Guests (See full list)
