tips for sealing off.... i can haz?
ChevyBoy95
You do not need to glass or foam. Trust me. Foaming is the lazy way. Y wall is all wood and weather stripping and I'd bet you can't get the panels out without knowing what angle to pull on them. I didn't even need to screw them in to the bracing but I did just because. I think the issue with his is that a flat plane puts it into the windows. Which then makes for a really weird shape
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
You are correct. You can't beat the panels when they fit like that. Very solid. I just think every application is different. My old cars wall panels were tight as hell against the B pillar trim. Now, in my truck, the location of the baffle made it very difficult to fit like that because of the angles and contours of the body. I'm still not 100% happy with my panels. So for me I may try glassing at some point. Just my thought.
that is my issue, the sides since they fit just into the windows, i have to get the right angle all the way up, plus, the 6 or so cuts below the window with how the stock panel is. There are so many angles and different cuts to make it is very irritating trying to get the panel to fit properly.
Build a beauty panel that sits really close to the edges of the side of the vehicle but not exactly on it, then put some weatherstripping on the edge of the panel so when the back door is shut, its airtight. Thats the way a buddy and I did it on my wall build in another car.
To get the measurement perfect all you need to do is measure every quarter inch top to bottom of the wall width-wise, trace it on mdf, sand the imperfections and attatch it to the side of the wall. Presto, you're done
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
MY EXT CAB DOESNT HAVE BACK DOORS, READ THE OP.
And btw buddy, it aint that easy when you have extremely limited access except for the spot where it slides in.
anyone know what the things are called that have a ton of vertical pins where you can press them onto a curved edge and the pins will move to taht shape?
Search my posts, I postdd a stupid easy way to do it but I don't wajt to type shat shit up on mobile again lol
Used to have a loud truck
thanks hoss, ill check it out.
and here is the gap... there are a few things below the picture [inside my truck] that have to be cut around aswell.
  • Who's Online   0 Members, 0 Anonymous, 3301 Guests (See full list)
