Knu 1/0 370a alternator ok with one run?
Talked to a few guys and I call bullshit .. A lot if competitors been running multiple lugs for years so have I ., I've had failure from under hood temps an ok I was wrong I have 3 lugs per alt lol four don't fit
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
I have 3.
2 per eyelet, and one for the vcm....
ill admit, ive only been running this for about 9 months. but......
also,.. was there not a post where the dude got told to do 2 ?
again.. im just wondering. I spent a LOT on my shit, no way i wanna lose it.
So I see where Mechman says not to use two connections in a blanket statement. Then later says back battery bank can backfeed? causing an issue, but no one said anything about back batteries..... What about people with a single underhood battery and H/O alt? No one shoul dhave extra runs?
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
i think the heated stud argument relies on the alt stud being the central connection point between rear and front batteries. If I am following this correctly.
Not everyone is wired the same. I have 2 runs off of the alt but its going straight to my rear bank then from there through step downs to a small 12v in the front.
I assume this makes me "safe" ?
Nope.. the 2 connections on the one stud is the issue where are talking about now... Where they go dont matter.
We are speaking of 2 connections at the ONE alt stud.
I call BS. If the connections are tight the alt stud doesn't care if it has two lugs on it.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   1 Member, 0 Anonymous, 1161 Guests (See full list)
