Voltage- How low is too low?
I don't like dropping under the batteries resting voltage. 12.7-12.8. That's my opinion
:werd_msword:
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
well from my understanding is that below 12.8 when your vehicle is running is when your alt can no longer support the electrical drain, so technically speaking that might be a strain on the alt going below that point. maybe I'm mistaken
09 Challenger R/T (Audio system under construction):
  • Pioneer AVH-X4500BT (PAC RP4CH11 harness)
  • (2) Sundown Audio SA-8v2 (inverted)
  • CT Sounds AT1400.1D
  • XS Power D3400
  • 40 sq ft. Audiotechnix deadener
  • 1/0 Audiotechnix wiring
  • stock Boston Acoustic 7 speaker amplified system (for now)
  • Sealed trunk enclosure
Build log:
http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/
TEAM GOAT
My next builds is assuming for no lower then 13 volts.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Fuck that mess. Below 10v is when I get scared. If you're running quality equipment, low voltage shouldn't really be an issue unless you're dropping super super low.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
most amps go into protect or get damaged @ 10 volts so if they EVER see that low it can be devastating damage done as they are made to always play higher than that.
11's is scary shit, 12's are fine IF* you dip into them temporarily but playing continuous in 12's is just not *great* idea. 13's are perfectly fine all day every day, 14's is F*cking ideal and should be your goal. (good luck)
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
  • Who's Online   0 Members, 0 Anonymous, 207 Guests (See full list)
