anyone have any replaced ac condencor with alt?
i have a 98 neon and its been a hard time trying to find an alt that will do what i need. i have dreams of 2 12s trunk car so im looking for a high amp alt ive asked before and people have suggested replacing the condensor with a one wire alt. has anyone actually done this that could give me some advice. i know i would need to modify or even a custom bracket. but how do you calculate how much power said alt is going to use off the engine. i plan to do a 2.4 out of a stratus swap with a complete rebuilt and hotter cams so im looking at a motor with around 200hp and a little less then that for tq. just trying to get an idea on what ill need to support an alt to make that kinda power on a daily aplication
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
first of all whats the setup how much power your gonna run second why take the ac compressor out unless a/c doesn't work, I need my a/c in Ga.
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
I would say just about 10hp maybe but I doubt you will feel it. I am sure it will have close to the same drag as the condenser.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Have you contacted Mike Singer for a alt rebuild? He rebuilt one for me on a 03 Lancer and now i have 200+ for my 3000 watt system and it handles it great. But i do have 3 batterys total. But he can rebuild anything at a great price. $400+ for mine and worth every penny.
if you are going to make a bracket, contact mechman and see if they can hook you up. They could only make a 160 or 180 for my car, but an S series with a bracket would fit, 240 amps ftw.
edit:
then you could keep your a/c
ive contacted dc with no reply mechman has one but i have to modify it and use a diff belt for it to work perhaps singer.
sent a message but i feel like ive done that before? so i may have already tried and gotten no reply
Singer is a burst guy can take him a while to get back to you.
As for a bracket to fit an alt where the AC is you could talk with local machine shops. It can be done but can cost a few hundred extra.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 4316 Guests (See full list)
