Question on my electrical
the other amp is a 50 amp fuse though would fusing it with 150 be appropriate?? I thought 250 for fosgate amp and 50 for other amp?
You can choose whichever one you want, the fusing is there to protect the wire.
I think that the first time the bass hits with the T2500bdcp, the car is going to blow the panels off and windows out making it easier to run the wiring.
Other than that, if your not going to run an upgraded alternator, remove the trunk lid, install a huge honda generator, and hook up a big battery charger to charge all times while you drive...maybe that will supply about 1/4 power you'll need.
t2500bdcp (basically 3500w) on a stock alt? oh boy. somebody call smokey the bear.
what kind of alt do you think ill need?
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Send mike singer an email with your plans and he'll get you an alt setup. I figure he'll probably build like a 220amp or so...
Or you could Email Mechman.
Or DC Power.
Or Ohio Generator.
DON'T Email TENNEY Alternators or IRAGGI Alternators.
biggest one you can fit in your car.
dc power. mechman.
Answer this: is this your first build?
my first real one with decent equipment yes
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
dc power. mechman.
ok i emailed singer and what i have so far that im ganna order today is this :
Description Quantity Unit price Amount Mini ANL Fuse Holder 1 $7.00 $7.00 50A Mini ANL Fuse(pack of 5) 1 $5.00 $5.00 RT ANL Fuse Holder 1 $8.00 $8.00 250A ANL Fuse 1 $4.00 $4.00 1/0 OFC Red 40 $3.64 $145.60 8ga OFC Speaker Wire 20 $1.75 $35.00 10 pack 1/0 Lugs(Black HS) 1 $20.00 $20.00 TM DIstro Block w/ 1 1/0 Input and 1 1/0 & 1 8ga output. - Clear plexi Top and Bottom 1 $35.00
$35.00
i already have the 2 250 amp fuses for under hood and at back battery
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
  • Who's Online   0 Members, 0 Anonymous, 1507 Guests (See full list)
