Question on my electrical
If you're running it at 3500 rms like you said, you'll probably blow a fuse somewhere down the line
? Why would a fuse blow?
Chris, could you draw a pic up, including fuse placments, and post it for him?
Thanks bro.
Wouldn't 3500w down a 250A fuse blow it? I'm probably wrong but I was told that a fuse amperage usually translates like 250A~2500w
Welcome to my sig :D
My build on my 2008 Jeep Grand Cherokee Laredo 4x4:
2 Sundown SA 12's
Sundown SAZ 1500d v3
Alpine CDE-HD148BT
Hertz 165 Speakers
Atrend Carbon Enclosure
Stinger SPP925 Battery
Sky High 2/0 & 1/0 Power Wire & Big 3
:domodance::domodance: Legal 145.2 dB. :morepower1: Team Sundown. :domodance::domodance:
cd64929e-8a60-41ea-b784-c5c6096f49b8_zps
Lol I'm at work for 9 more hours. Will draw/post when I get home.
What alt do you have? What do your have for front and rear batteries?
stock front and stock back until I can replace with a d3100 in back. 120 amp alt I don't wanna have to put another in this car isn't Ganna last to much longer lol
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
I'd you don't have a volt meter, get one. Those amps draw tons of power and you'll need to watch it.
What alt do you plan on getting?
Caleb.. If I can make a recommendation for an alternator.. SingerAlternators.com
Mikes the fucking man.
Then.. DC Power.. then, Mechman
Thats just MY order
I agree with Chris, pick up a VM. You don't need an expensive, fancy one by any means.. A $20 Stinger one will do.
For 1/0 CCA AWG run, a 250A fuse will be good.
For the speaker wire question.. How many of the RF outputs will be used?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
i got a stinger volt meter and also not sure on alt can't find one for a 2000 Saturn l series :/
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Thats just MY order
uh no idea I guess just one pos and neg or what would be my best bet ? Will be at 2 ohms
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Fusing 0 Gauge CCA to 250A is risky business, if you are unlucky the wire melts before the fuse blows. (especially if you drain 200-240A continuously
Normally you shouldn't get to 250 amp with only the T2500, but it's possible.
  • Who's Online   0 Members, 0 Anonymous, 4424 Guests (See full list)
