60Amp fuses= ?wattz
Rck'nRF
The general rule of thumb due to taking some power away for efficiency, is fusing x 10 = a general power output.
5k generally need 400-500a of fusing
2k generally need like 150-200
etc.
Amps x volts = watts
Can't make more than you consume.
So with 2 60 amp fuses even at 14.4 then the max wattage out is 1728 watts
Do the math based on real input voltage and even then that number doesn't mean anything unless the amp internally is capable of transforming the input power into output efficiently
That is considering the amp is 100% efficient as well. More than likely if it is being run at 1 ohm and is a class D amp it is going to be in the 50-65% efficiency range, which would mean it may be capable of 1100 watts at the absolute max.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
I made the ASSumption he knew that no amp is 100% efficient, that's why that last line is in there. Should of known better to assume though
Rolex you sicken me.
Just let me finish my pie
~ Juice
Well, if he was asking in the first place I doubt he has any clue what efficiency and amplifiers have to do with one another.
1 XS Power D3100
Audio Control LC6i
Stock Deck
You got it all wrong. P*X^c / f + c*t(4.55634 * x) +r
Edit forgot a decimal
Dude you is trippin. Lol :)
1 XS Power D3100
Audio Control LC6i
Stock Deck
i still like looking at some amps with BS ratings and looking at the fuses.
like say my old sony xplod amp that says 1200 watts and it has 2 30 amp fuses couldn't do 1000 watts if it wanted to
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
http://www.kijiji.ca/v-electronics/edmonton/pioneer-premier-power-amp-mint-condition/333011595
So do i!
Here's some more comical-ness that this dude claims:
"2400 giga-a-watts"
Thats a pawn shop, lol
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 582 Guests (See full list)
