What sub should I get??
SirJimbles
Well I looked under my hood and all the alt says is "dr44" is there any way to find out how many amps it puts out?
It's prolly not big enough for what you are trying to do. Yes, it will play, but you are prolly going to run into clipping problems from low voltage. At bare minimum, I would get a new battery under the hood and a secondary battery in the back. Upgrade Big 3 and install a voltage meter of some kind so you can see what's going on. That will tell you if you need a HO alternator, which most likely you will (I'm running around 1700RMS and I went ahead and upgraded to a 240a HO alt., HUGE DIFFERENCE). I'm no expert at this by any means, so if someone who has more knowledge than me wants to chime in, go for it. As mentioned above, any of those subs will work, although if i had my pick and was on a budget, I would go SoundQubed. Solid sub for the money and will handle every watt your Memphis can throw at it. If it were me, I would address electrical first, then either build or find someone to build a solid enclosure, then install the system. Not advisable to work backwards after you have already damaged your amp and sub. Just my 2 cents for what it worth....
2013 Toyota Camry SE
240a MechMan HO Alternator
1/0 Welding Flex Cable Big 3
CT Sounds 4000.1D
Kenwood XR400-4 Mid/High Amp
SoundQubed Q4-120 Mid Amp
Infinity Kappa 6.5 components
Kappa 6x9's for rear deck fill (coming out)
(4) 8" PRV 8MB450's
Set of SoundQubed SuperTweets
(2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure)
(2) SQ HDC3 10's @ 33.5hz (current build, loving them)
Pioneer AVH-X4600BT
100 sq/ft Stinger RoadKill Sound Deadner
120 sq/ft QMat Sound Deadener
(4) Juice Box Black Cherries
Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0
2 Runs of 1/0 Positive front to back
ToolMaker Everywhere
You might could get away with powering two FI BL 15s or 18s. Just my $.02
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
Stock it's probably a 130 amp alt. Aka not much especially with a juice hungry amp
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Well this past Friday i bought the dc level 5. I will be running zero gauge through-out including the big three. Also, i'll have a battery in the back (not sure what battery though. input on this would be greatly appreciated). i'm building my own box so I could also use a design if someone could be so nice. thanks.
  • Who's Online   0 Members, 0 Anonymous, 3225 Guests (See full list)
