Splicing 1/0 - dang it!
@snowdrifter - Yes it's in the middle of the run.
Here's what happened.
I had 1 run of 1/0 front battery to rear battery. Tech (ordertaker?) at Knukoncepts said that the wire could handle 360amps for my 20ft run. I knew it was borderline, but went with their fuseholder that holds 3 mini-anl fuses. I used 3 @ 120 amps for 360amps. Anyway, last summer in the heat I melted the fuseholder without blowing a fuse. Not safe.
The wire I'm extending was originally run from my rear battery (inside truck) to the bed for my compressors. I am redirecting that wire towards the front for the 2nd battery to battery & reduce the fuse sizes on both runs. Then run a complete new run front to bed for compressors.
The wire hooked to the rear battery would be way too hard to replace. It's threaded through & under the sub box.
'09 Sierra Ext Cab - under construction
(1) RF T2500-1 -running- (4) RF T1 12's
(1) RF T1000-4 -running- (2) RF T1652-S
Stock alt / battery -plus- (1) DC Power 230a & (2) Kinetik 1800
Buncha OFC Knu
Buncha Second Skin
Kenwood DDX814 - Alpine Imprint - RF 360.3
Hmmm. The extra fuse isn't a bad idea.
Least resistance though?
Buncha OFC Knu
Buncha Second Skin
I used this:
Its a Stinger 1/0 Coupling connector
What happened to the welding connector? :unknw:
I used the welding connector for the neg run, and the Stinger for the pos :) Thanks again :good:
Maybe I have those confused.. Either way, I have both LOL
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Holy double posts I have been seeing lately. If it is in the middle where having a 6-8in part of it being straight, and not conscerned about the felxability in the immediate location of the wire. I don't see why using one of those copper sleeves wouldnt be a bad idea.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
I don't want the install police after me!
So did you buy the sleeve or flare a piece of copper pipe?
Buncha OFC Knu
Buncha Second Skin
That sleeve will work, but it has the potential be a serious choke point.
Most likely, only the outer most wires are making contact with the sleeve on each end of the splice.
Make a new run if possible. Up to you though.
  • Who's Online   0 Members, 0 Anonymous, 487 Guests (See full list)
