CortezDTV Posted April 2, 2014 Report Posted April 2, 2014 Um Only important question not asked What car? I don't know any trunks that can hold 2 15s let alone debating 2 8" are ports SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/
faralint Posted April 2, 2014 Author Report Posted April 2, 2014 Um Only important question not asked What car? I don't know any trunks that can hold 2 15s let alone debating 2 8" are ports Audi a6 c5 (1988) check buil log Build log - http://www.stevemeadedesigns.com/board/topic/173832-audi-a6-trunk-build/page-3
slowfkncar Posted April 2, 2014 Report Posted April 2, 2014 At 5cu.ft net for both subs you will be fine with a dc10k as long as 1. You have very good electrical 2.you dont have to much port area for so small of an enclosure and 3.you have the newer style XL's. My only concern is your electrical. I have two soundqubed 3500.1's strapped on 3 batts (3600 cca 375ah) on a 250a alt, while driving i can dip from 14v to 12.9v
MarioB Posted April 3, 2014 Report Posted April 3, 2014 Um Only important question not asked What car? I don't know any trunks that can hold 2 15s let alone debating 2 8" are ports I was thinking the same but he could maybe do subs up ports forward... 12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodcsoundlab.com Quality is all in how you take pictures I have plenty of projects that look WAY better on camera then in person crazy to fit so many in so little. Reminds me of some of the porns I've seen?
faralint Posted April 3, 2014 Author Report Posted April 3, 2014 Um Only important question not asked What car? I don't know any trunks that can hold 2 15s let alone debating 2 8" are ports I was thinking the same but he could maybe do subs up ports forward... yes. sub up/port forward or may be sub up/port back... If subs and port forward. i can't use flared port. ( only one 8" or slot port ) Build log - http://www.stevemeadedesigns.com/board/topic/173832-audi-a6-trunk-build/page-3
alaskanzx5 Posted April 3, 2014 Report Posted April 3, 2014 In case this pipe dream goes up In smoke I want to be able to watch this thread. imo, 2 15 is hard to do from a trunk. Giving dimensions would help us understand what area your trying to force them into. Also if running at .5 ohm you need much better elec imo. the suggestions of different subs would be wise to consider. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
BassJunkie Posted April 3, 2014 Report Posted April 3, 2014 I'm going to go ahead and assume alot of these posts were april fools day posts lol 1986 C20 Suburban 9 American Bass XFL 15's B2 M1MKII 14v XS Power Batteries Maxwell Caps Acoustical energy is free. Electrical energy is not you havent lived until you've hit a screw with a router.
pa-pa-platypus Posted April 3, 2014 Report Posted April 3, 2014 2 15's firing forward with an 8" port may or may not get loud sometimes This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
pa-pa-platypus Posted April 3, 2014 Report Posted April 3, 2014 firing up with a 3 6" firing forward is also a possibility it may or may not work... keep 2 8" handy for the subs up its been known to work 2 This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
faralint Posted April 3, 2014 Author Report Posted April 3, 2014 In case this pipe dream goes up In smoke I want to be able to watch this thread. imo, 2 15 is hard to do from a trunk. Giving dimensions would help us understand what area your trying to force them into. Also if running at .5 ohm you need much better elec imo. the suggestions of different subs would be wise to consider. dimension's is 40.15*15.74 and about 39-40 depth Build log - http://www.stevemeadedesigns.com/board/topic/173832-audi-a6-trunk-build/page-3
