C2 Audio Team 1K 12 - aero port enclosure
TzA
I used Torres Calculator. Helped me mess with dimensions more easily.
Here is what I have come up with:
I will be cutting all wood rounded to nearest whole number, to match that of the Torres Cut Out Specs.
Port: 8" x 25" port gives me 14.10in SQ/cubic foot. Total 50.24in SQ of port area. I think that should be big enough.
Port is 8" away from the wall.
Their are also 2 rods bracing.
This is one of the only ways I could get an round port back and subs up.
From what I was gathering, this is typically the better set up in an SUV, I was hoping to do subs up and port to the side. But am unsure how that would sound.
How far away does the port need to be from the rear of my SUV?
F O.
Ok. I believe this is what I am going to build. ended up with 4" ports. Did not have enough clearance for the 8" port facing rear.
What do you guys think? Any suggestions? Input?
F O.
Are you making your own ports? The flares are going to run in to each other. The lip of the flare is much wider then the diameter of the port itself. You might just want to go slot port but if you think you can do it try it out.
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
With the latest design, I think I am not going "aero port", but rather round port... using a router to round off any and all edges..
But, i was also speaking with Chris (owner of C2 audio) and his rule of thumb for aero ports is 1 4" port per 12" woofer...
So if I do 2 4" ports, I can make them 'aero'... still in the gathering information and design mock-up stage..
Maybe just a single 6" port would be best.. not sure at this point.
Do you have any suggestions BoomZoom808?
F O.
Either one should work build it and let er rip.
2010 Mazda 3s 2.5L
Knu OFC 1/0
If those subs are really 32mm Xmax 1 6" on full excursion will not be enough or 2 4" for that matter, 3 4" ports flared on both ends would be the least reasonable amount and that around a 35Hz tuning.
going to probably start the build within the next few weeks. Subs have not even started shipping yet, probably a few more weeks for those..
Give me some input, or don't! this is what I am going to go with!
F O.
Make sure you build bracing to hold the ports in place, instead of trying to have the baffle do all the work.
Other than that I think you just need to have those subs sent to ya and build that box!
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
I wish I could speed up their shipping process.
Ya, I was thinking of building something around the ports on the external portion for added strength and to just look a tad better.
I will try to figure out something that can assist on the internal portion of the port as well. thanks.
going to start the build tomorrow. will try to post pics as I go, but i it will be a long process with the timing and it is getting quite hot out here in AZ.
I appreciate your help. thanks.
F O.
I don't know your level of woodworking skills, but one of the best bracing methods is shelf bracing. Where you cut a little grove all around the box where the bracing will fit to create a "shelf". This allows for the best connection and depending on the wellness of the bracing design, is tough to beat.
  • Who's Online   0 Members, 0 Anonymous, 7459 Guests (See full list)
