roycealbert1 Posted April 9, 2014 Report Posted April 9, 2014 i just got this taramp 5000w 2 ohm stable amp. its running to my sp4 18 at 4 ohms and it says it does 4000w at 3.8v and 3335w at 12.6v i had this sub going off a saz 2500 before at one ohm and it played waaay louder than it does with the taramp. i only have one strand of power and ground going to it just btw and the line fuse is a 160a. and i have two batteries with a 200a alternator with all 0 gauge wire. so i was wondering if anyone knows about this amp if i could get away with running it at 1 ohm daily.
Dangrebel Posted April 9, 2014 Report Posted April 9, 2014 It will not handle a 1 ohm load. Except for burps. Why didn't you get the 1 ohm model? 1999 GMC Yukon, 6 PSI platform 5 18's, 4th order bandpass by BHE, Taramps,
TaylorFade Posted April 9, 2014 Report Posted April 9, 2014 Do not run a 2 ohm version at 1 ohm. How did you set your gains? And why in the hell do you have a 160A fuse on a 5k?
Miguels Posted April 9, 2014 Report Posted April 9, 2014 well here it goes.. impedance rise is a bitch if its wired at 2 ohms i wouldnt be surprised if its rising to 16 ohms.. the lower you wire the less rise you have my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
roycealbert1 Posted April 9, 2014 Author Report Posted April 9, 2014 Do not run a 2 ohm version at 1 ohm. How did you set your gains? And why in the hell do you have a 160A fuse on a 5k? well my gains are almost maxed out before clipping and its wired to 4 ohms so its suppose to be pushing about 3500w and i just havnt got another fuse yet
roycealbert1 Posted April 9, 2014 Author Report Posted April 9, 2014 well here it goes.. impedance rise is a bitch if its wired at 2 ohms i wouldnt be surprised if its rising to 16 ohms.. the lower you wire the less rise you have well ive read that some guys have ran these amps below what they are suppose to daily and were fine. i dont have the electrical for 5k and at one ohm this amp will do 6000+ according to its specs. but i would have the gain probably about half.
SoCaLBaMF Posted April 9, 2014 Report Posted April 9, 2014 No..... just no... 2004 Bagged Trailblazer (4)18" Sundown Nsv3s (4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4 (2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
Ninja_v1.0 Posted April 9, 2014 Report Posted April 9, 2014 :throws hands in air: When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
dolarbilz Posted April 9, 2014 Report Posted April 9, 2014 :throws hands in air: Thrown your mutha fucking hands in da air wave dem like you don't care oooohhh oooohhhhh now scream
Miguels Posted April 9, 2014 Report Posted April 9, 2014 well here it goes.. impedance rise is a bitch if its wired at 2 ohms i wouldnt be surprised if its rising to 16 ohms.. the lower you wire the less rise you have well ive read that some guys have ran these amps below what they are suppose to daily and were fine. i dont have the electrical for 5k and at one ohm this amp will do 6000+ according to its specs. but i would have the gain probably about half. half gain dont mean half power. you can be getting all power at 25% of the gain.. it all depends on the HU and its your job to gain match my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
