CJ18 Posted April 30, 2014 Author Report Posted April 30, 2014 If anything a larger amp would probably yield larger differences. Im pretty sure thats why he suggested a bigger amp I know that the bigger amp will yield a bigger difference. Its just which way will that difference go. I think some of you are going to be surprised.
Wicks Posted April 30, 2014 Report Posted April 30, 2014 Look at the cross sectional area of your 300a fuses...not big. How much voltage drop are you getting across your fuses...? The MASSIVE chunk of wire is useful for long cable runs to reduce the overall voltage drop. How thick do you think the traces on the circuit board in the amp are and they conduct that full current... This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
hdorre Posted April 30, 2014 Report Posted April 30, 2014 Ohh, im not doubting it at all. As usual, Im in for the vid On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
CJ18 Posted April 30, 2014 Author Report Posted April 30, 2014 Test was done with the Shok 2. 2600w at 1 ohm 14.4v Each scenario was run 10 back to back to back times on the dyno to give a large sample size. All 10 tests will be added together and then the average taken. Test 1- Bare copper wire Test 2- 1/0 to 1/0 Input By the logic being argued here, the 1/0 inputs should yield a lower number since it is an added link in the chain. Also since it is aluminum and not the copper wire. So if these tests show the same power or more, then that should prove that the 1/0 inputs do have a purpose and should not be considered useless.
CJ18 Posted April 30, 2014 Author Report Posted April 30, 2014 Oh and I will pre apologize for the length of this video. I am putting the 3 videos that I took together and will not edit anything. Every last piece of the test will be shown.
audiofanaticz Posted April 30, 2014 Report Posted April 30, 2014 My only main issue is this, and it goes for almost all these blocks being sold, not just these specific ones in this thread. With my previous 2/0 to 1/0 reducers I got from SkyHigh made by toolmaker. I just dont trust the fact that you have a screw holding the block into the terminals, if you wiggle a little bit you can pull the wire and terminal block out the amp, no matter how tight you tighten the screw on the amp. A flat screw or allen bolt on a flat piece of metal is nothing to great. Even Orionstang said he checks his connections once a month because things loosen up. I tried it, and it scared me. To think how many vibrations are in some vehicles screws loosening up, terminals possibly falling out The problem needs to be looked into, said this before, but nothing happened apparently. These where flat on the top, just like the ones in this thread. Until I drilled slightly into them for the screw to be able to be inserted slightly and lock them into place.
OrionStang Posted April 30, 2014 Report Posted April 30, 2014 Good idea there^^^ SMD Super Seller My Feedback Thread
sprkn_ranger Posted April 30, 2014 Report Posted April 30, 2014 That's an awesome idea audiofanaticz. Is that something that could be a pretty generic fix or does the placement of the set screws vary from amp to amp where it wouldn't be a "one size fits all" type of deal? Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
CJ18 Posted April 30, 2014 Author Report Posted April 30, 2014 My only main issue is this, and it goes for almost all these blocks being sold, not just these specific ones in this thread. With my previous 2/0 to 1/0 reducers I got from SkyHigh made by toolmaker. I just dont trust the fact that you have a screw holding the block into the terminals, if you wiggle a little bit you can pull the wire and terminal block out the amp, no matter how tight you tighten the screw on the amp. A flat screw or allen bolt on a flat piece of metal is nothing to great. Even Orionstang said he checks his connections once a month because things loosen up. I tried it, and it scared me. To think how many vibrations are in some vehicles screws loosening up, terminals possibly falling out The problem needs to be looked into, said this before, but nothing happened apparently. These where flat on the top, just like the ones in this thread. Until I drilled slightly into them for the screw to be able to be inserted slightly and lock them into place. I do agree with you there. The only hard part about doing this on the manufacturing side, is that you have to make products to fit as many products as possible. Most amps are close to the same, but have slight variations. If one is just barely off, then it may not work. It is an easy thing for the end consumer to add though to finish off the product with their amp.
sprkn_ranger Posted April 30, 2014 Report Posted April 30, 2014 Well that answered my question lol. Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
