Beast Posted April 30, 2014 Author Report Posted April 30, 2014 Never mind i just got off phone with buddy of mine at advanced auto, he said that they have a agm charger and would be happy to charge it for me. That should get me by until i can get a proper charger. Im doing the install this weekend, got the new amp in BRX 2400D after the BRX2000D crapped out on me. Ill be doing a negative run from the batt under the hood to the 3400 in the trunk (unibody car) Im going under the car for this and cutting a hole in the trunk. Protecting the second wire with rubber water-proof flex conduit. Then of course ill clamp it in place inside and out and addin a bit of silicone to make sure it don't leak. Only other thing i can think of is to check all my previous wiring under the hood to make sure iv'e got it all hooked up proper. Then once all thats done ill be back to booming.
Kyblack76 Posted April 30, 2014 Report Posted April 30, 2014 Fuck, i was joking?? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Soccerballzs Posted April 30, 2014 Report Posted April 30, 2014 Also per XS Power at 10 amps. KyLar knows!! http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
shepherd92683 Posted April 30, 2014 Report Posted April 30, 2014 Can one of y'all recommend a charger please? Preferably one in the 50 dollar range (budgets tight) Get a battery tender plus if you want an inexpensive good quality charger. You will need it over the years and they are cheap. I think I paid $40 for mine and it has paid off in spades. 2017 Honda Accord Touring Build coming soon
Dan2427 Posted April 30, 2014 Report Posted April 30, 2014 Serious question and kind of a thread jack.. What's the difference between agm charging and wet cell charging? I mean isn't a charger for a wet cell charging at 13 to 14 volts the same as the agm charger charging at 13 to 14 volts as well? (Both getting a 6 amp trickle charge) if their is a difference I just wanna know myself for personal knowledge. 2003 GMC Yukon Denali Alpine CDA 117 Redoing Mids/Highs 4 Runs of 1/0 Knukonceptz 2+, 2- 4 Deka 9A31's in back (Stock underhood) 250 amp Alt. AQ20K 2 18" Crossfire XS V.2's 12 cubes 33hz 149sq inches of port!
Rmichael91 Posted April 30, 2014 Report Posted April 30, 2014 Never mind i just got off phone with buddy of mine at advanced auto, he said that they have a agm charger and would be happy to charge it for me. That should get me by until i can get a proper charger. Im doing the install this weekend, got the new amp in BRX 2400D after the BRX2000D crapped out on me. Ill be doing a negative run from the batt under the hood to the 3400 in the trunk (unibody car) Im going under the car for this and cutting a hole in the trunk. Protecting the second wire with rubber water-proof flex conduit. Then of course ill clamp it in place inside and out and addin a bit of silicone to make sure it don't leak. Only other thing i can think of is to check all my previous wiring under the hood to make sure iv'e got it all hooked up proper. Then once all thats done ill be back to booming. Did you think about running the wire through a pvc pipe with angled fittings? Just an idea to protect the wire, I've got a unibody car too and my firewall's a bish to deal with.
Beast Posted April 30, 2014 Author Report Posted April 30, 2014 Never mind i just got off phone with buddy of mine at advanced auto, he said that they have a agm charger and would be happy to charge it for me. That should get me by until i can get a proper charger. Im doing the install this weekend, got the new amp in BRX 2400D after the BRX2000D crapped out on me. Ill be doing a negative run from the batt under the hood to the 3400 in the trunk (unibody car) Im going under the car for this and cutting a hole in the trunk. Protecting the second wire with rubber water-proof flex conduit. Then of course ill clamp it in place inside and out and addin a bit of silicone to make sure it don't leak. Only other thing i can think of is to check all my previous wiring under the hood to make sure iv'e got it all hooked up proper. Then once all thats done ill be back to booming. Did you think about running the wire through a pvc pipe with angled fittings? Just an idea to protect the wire, I've got a unibody car too and my firewall's a bish to deal with. Well the conduit im talking about is outdoor Electrical conduit. I have used it before when i lived on a 35 acre piece of property its good shit and is just about anything proof. Its kinda like a garden hose but alot thicker.
