ChevyBoy95 Posted May 1, 2014 Report Share Posted May 1, 2014 Was wondering this. In my testing with my oscope I have set gains on my CT 7k, CT 4k, AA 500.1, SS X3.71, Nendo 5500's, 3500's, and so on (lot of korean amps). Every time, say i would set the gains with 35hz for example to the point of no clipping. If i then played a 33hz tone, or 32, 31, 30, 29,....... it would ease into soft clip, and heavy clip in the mid 20s. Hopefully that made sense. Amp would put out more signal voltage too, and this is unloaded btw, all tones at -5db amplitude, SS all the way down (15hz), lpf all the way up (~150hz). Anybody know the reason why? what is going on internally with the amplifier or signal received that causes this? was just curious. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
EP95 Posted May 1, 2014 Report Share Posted May 1, 2014 Probably wrong but Ima guess lower notes are harder on the amps. Maybe? Link to comment Share on other sites More sharing options...
Swordlordboy1234 Posted May 1, 2014 Report Share Posted May 1, 2014 I know a few people way smarter then me with engineering backgrounds that have answered this. Answer is yes. Explanation is because multiple people have told me exactly why and i forgot what they said other then "yes, they do clip sooner then higher frequencies" In to see smart people explain. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect? Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted May 1, 2014 Author Report Share Posted May 1, 2014 I know a few people way smarter then me with engineering backgrounds that have answered this. Answer is yes. Explanation is because multiple people have told me exactly why and i forgot what they said other then "yes, they do clip sooner then higher frequencies" In to see smart people explain. that is what im looking for... the "smart" explination Probably wrong but Ima guess lower notes are harder on the amps. Maybe? really? lol. Hopefully Tony or someone will chime in with an EE background or someone with a lot of amplifier experience. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
EP95 Posted May 1, 2014 Report Share Posted May 1, 2014 Like I said, just guessing. Link to comment Share on other sites More sharing options...
tacomaguy1 Posted May 1, 2014 Report Share Posted May 1, 2014 idk, but I get a lot more voltage drop playing higher notes....can get subs to smell a little. They're harder on my setup can play lows all day long, good voltage Team Flex Issues Link to comment Share on other sites More sharing options...
Guest Posted May 1, 2014 Report Share Posted May 1, 2014 probably box rise. Link to comment Share on other sites More sharing options...
gckless Posted May 1, 2014 Report Share Posted May 1, 2014 When you did this, you were setting at max volume right? Do this: do the same test again, but do it at half volume, so that electrical supply isn't a factor. Bet you get different results probably box rise. He said it was unloaded. "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography Link to comment Share on other sites More sharing options...
Tarball Posted May 1, 2014 Report Share Posted May 1, 2014 what is your box tuned to. Remember below tuning your impedance is going to drop requiring more voltage. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
gckless Posted May 1, 2014 Report Share Posted May 1, 2014 what is your box tuned to. Remember below tuning your impedance is going to drop requiring more voltage. He said it was unloaded. "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography Link to comment Share on other sites More sharing options...
