timc31610 Posted May 6, 2014 Report Posted May 6, 2014 It would look something like this. This is for illustrative purposes only...lol My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
harlemn8ive Posted May 7, 2014 Author Report Posted May 7, 2014 It would look something like this. This is for illustrative purposes only...lol OK. My only question is wouldn't this type build block at least some of the sound coming back into the cabin? Check out my build slow but... slow and steady wins the race http://www.stevemeadedesigns.com/board/topic/185561-1st-build-budget-toyota-mark-2/
timc31610 Posted May 7, 2014 Report Posted May 7, 2014 It may, but i would guess no more than just the 29" wide box. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
harlemn8ive Posted May 7, 2014 Author Report Posted May 7, 2014 was going to face it inward. maybe i should start from scratch Check out my build slow but... slow and steady wins the race http://www.stevemeadedesigns.com/board/topic/185561-1st-build-budget-toyota-mark-2/
timc31610 Posted May 7, 2014 Report Posted May 7, 2014 Sub/port toward cabin? Do your seats fold down? My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
harlemn8ive Posted May 7, 2014 Author Report Posted May 7, 2014 Sub/port toward cabin? Do your seats fold down? Originally i wanted the port and subs facing in. the seat doesn't fold down just the arm rest. would it be best to attempt to design a box facing the rear? Check out my build slow but... slow and steady wins the race http://www.stevemeadedesigns.com/board/topic/185561-1st-build-budget-toyota-mark-2/
Joe X Posted May 7, 2014 Report Posted May 7, 2014 You only need a 5" port to make those subs work, if you insist to use the narrow section without modding anything you could do something like this: Also you can perfectly do a back firing setup as long as you give sound waves a return path, I am pretty sure that if you build in the wide section a simple rectangular shaped box could be large enough if your given dimensions are accurate.
harlemn8ive Posted May 7, 2014 Author Report Posted May 7, 2014 Thats a funky lil box. Possibly out of my comfort zone I am almost will willing to give it a shot i see it would need a double baffle. calculations would need to be perfect. im going to sit on this one for a little bit. more than likely i will go with a rectangle box but this really give me some ideas Check out my build slow but... slow and steady wins the race http://www.stevemeadedesigns.com/board/topic/185561-1st-build-budget-toyota-mark-2/
Joe X Posted May 7, 2014 Report Posted May 7, 2014 Thats a funky lil box. Possibly out of my comfort zone I am almost will willing to give it a shot i see it would need a double baffle. calculations would need to be perfect. im going to sit on this one for a little bit. more than likely i will go with a rectangle box but this really give me some ideas Yes, in fact the sketch belongs to another design (not necessarily means yours need a double baffle), I just wanted to show you a way to deal with the issue, as said before just building in the wide section solves the issue.
dharris2488 Posted May 8, 2014 Report Posted May 8, 2014 I'm writing this because I want to see the end result. Just bought (2) HDS3 12's with a Q2200.1 and I need to build an enclosure this weekend. I will start my own post, as to not hijack this one. Just curious to see what his final dimensions and tuning are going to be. Also curious to see if rear firing will be better in this case, rather than forward firing. Good luck! 2013 Toyota Camry SE 240a MechMan HO Alternator 1/0 Welding Flex Cable Big 3 CT Sounds 4000.1D Kenwood XR400-4 Mid/High Amp SoundQubed Q4-120 Mid Amp Infinity Kappa 6.5 components Kappa 6x9's for rear deck fill (coming out) (4) 8" PRV 8MB450's Set of SoundQubed SuperTweets (2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure) (2) SQ HDC3 10's @ 33.5hz (current build, loving them) Pioneer AVH-X4600BT 100 sq/ft Stinger RoadKill Sound Deadner 120 sq/ft QMat Sound Deadener (4) Juice Box Black Cherries Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0 2 Runs of 1/0 Positive front to back ToolMaker Everywhere
