material questions
whats better to use as far as strength and sq i can get mdf for about 35 a sheet but then i saw some wicked nice birch and oak plywood thts 54-57 a sheet.
im planning to build an enclosure for 4 cu ft net. and want a tripple baffle wioth a flush beauty panel as a 4th. so the idea of having to prolly get to sheets is a realistic one.
is there any advantage to the more epensive plywoods
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
unless its 13 ply grade bb/bb wood is pretty much junk, with inner cores of douglas fir plywood, that cheap 20$ per sheet wood, filled with knot holes, with a thin 1mm veneer that is birch or oak which adds nothing for strength.
Sure its lighter than mdf, but its also less dense and weaker, not to mention almost $20 per sheet more.
Good birch 4by8 13ply panels sell for 70 plus usually.
My two cents....
When you can make a vehicle the perfect acoustical environment for audio reproduction the differences in density between baltic birch and MDF might become a factor. Until then, it's a waste of money unless your primary focus is weight.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
wieght isnt really an issue nor is cost. performance and strengh is i plan to brace the hell out it it with either material
  • Who's Online   0 Members, 0 Anonymous, 2843 Guests (See full list)
