Kyblack76 Posted June 4, 2014 Report Posted June 4, 2014 Thanks mate. With out giving away, to much cuz I'm scared, it won't be long now. ;( SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
tacomaguy1 Posted June 4, 2014 Report Posted June 4, 2014 a lot more comes into play about an amp blowing than wired low Team Flex Issues
Kyblack76 Posted June 4, 2014 Report Posted June 4, 2014 a lot more comes into play about an amp blowing than wired low YUuup SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
DylanBunch Posted June 4, 2014 Author Report Posted June 4, 2014 What do you mean? Like voltage, gains, music going through it? 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
Cardboardcat15 Posted June 4, 2014 Report Posted June 4, 2014 Stout as fuck electrical and a knowhow of the volume knob. .5 is a big difference from 1ohm, ive yet to run .5 just because i know i didnt have the elec to do it. Make sure your bases are covered. My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
tacomaguy1 Posted June 4, 2014 Report Posted June 4, 2014 What do you mean? Like voltage, gains, music going through it? Db-r was saying voltage hardly ever causes an amp to go, they should protect....think he said main causes were Vibration Wiring it up wrong Bad solder job from factory Sub goes bad and takes out amp Team Flex Issues
Jerry Fang Posted June 5, 2014 Report Posted June 5, 2014 I'm no expert, but all I know that to be able to go very low impedance .5ohm-.25ohm you need power. 14v-16v constant and make sure the amp can go low. You mention it's a dc5k amp and that amp can do .5ohm. If it underpower, it'll blow at that impedance. If your charging is below 14v, I'll stay away from going pass 1ohm.
boom50cal Posted June 5, 2014 Report Posted June 5, 2014 I'm no expert, but all I know that to be able to go very low impedance .5ohm-.25ohm you need power. 14v-16v constant and make sure the amp can go low. You mention it's a dc5k amp and that amp can do .5ohm. If it underpower, it'll blow at that impedance. If your charging is below 14v, I'll stay away from going pass 1ohm. you must not have heard of Jason Myers....11v demos alllll day lolol as I have heard/seen audiofanaticz say, it's not so much about voltage as it is power to back it up. Keeping it cool, and clean, and you should be good On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
Wicks Posted June 6, 2014 Report Posted June 6, 2014 Just because you're "wired at 0.5" doesn't mean your actual impedance is at 0.5. MANY factors can raise your impedance. Daily I'm wired to "1 ohm"......an impedance sweep showed my true lowest impedance was closer to 1.78 ohms. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
Kyblack76 Posted June 6, 2014 Report Posted June 6, 2014 I'm no expert, but all I know that to be able to go very low impedance .5ohm-.25ohm you need power. 14v-16v constant and make sure the amp can go low. You mention it's a dc5k amp and that amp can do .5ohm. If it underpower, it'll blow at that impedance. If your charging is below 14v, I'll stay away from going pass 1ohm. Constant over 14v !?!? I don't even see that high not running anything, with everything g off. Lol. You need to read more. Or do more. I don't get the "you better have elec to do it" that isn't the end all be all running wired down. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
