Need help; terminal cup in a fiberglass enclosure leaking air, what now?
philrab
Title says it all. Have a fiberglass stealthbox custom made for my car I picked up used off another owner. Spent today chasing a few air leaks, and got them all we'll sorted EXCEPT the leaking terminal cup. Seams as though air is leaking directly through the center, like where the speaker leads attach rather than from around the edge.
1. What's the best way to deal with this? Was thinking pack it with epoxy to seal the bastard up, any other opinions. I don't have the fiberglass skills to be comfortable removing it and fixing the resulting hole.
2. Seams the preferred method is either direct leads out the box or bolts to act as studs. Any potential issue drilling through fiberglass, cracking or splintering?
Any advice would be appreciated. Sooner or later, I'm going to but up and learn to do fiberglass work, but right now I'm trying to fix the mess I found.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
fiberglass doesn't really split or crack, but it can splinter. If you decide on direct leads, I'd use a metal drill bit so it's cleaner. I'm guessing the terminal cup is plastic so I'd use some CA glue to seal it up depending on the size of the hole.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
have you thought about some kind of foam ring on the backside to help seal it up when you tightened the screws down? If it would work for you it would be a lot less messy than gluing it down, in the event that you have to remove it in the future.
Never mind, didn't read it properly. Thought air was leaking around the cup.
2007 Ford F-150 Reg. Cab. Flareside
250 Mechman Alternator
Sky High Car Audio Big 3
XS Power D3400
Rockford Fosgate 1/0 amp kit
Rockford Fosgate T1500-1bdcp
Rockford Fosgate T400-4
DC Audio Lvl 4 12"
Rockford Fosgate Punch 6.5" component
Rockford Fosgate Punch 6x8
Pioneer AVH-P2300DVD
SMD Volt Meter
Nope, air leaking right through the damned wire connections. Never using another terminal cup after this (not like I built this enclosure to begin with.
What I'm thinking is the following. Feel free to jump in and stop me if I'm being a knucklehead about it.
The fix: Take some spare bolts, and drill right through the terminal cup. Crimp ring terminals onto speaker wire inside the enclosure, and run the bolts through from inside out.
Pack the outside of the terminal cup full of epoxy and thread a nut onto the outside. Once dry, secure speaker leads using another set of nuts to run to the amp. Should be solid, epoxy should stop the leaks, I can always use a dab of silicone in the drilled holes for extra insurance.
Any of that sound way off base???
Build Thread
I vote hot glue first..
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
The terminal cup is likely the weakest part of your enclosure. If you are going to go through all of that it would probably be better to do as you said in your opening post and just glass it over and use bolts. Can you hear the air leaking out? is it so bad that is is affecting your output?
A. I've never fiberglassed before. Epoxy I can do.
B. I can actually hear the air whistling out on lower bass notes. It's nowhere near as bad now that I sealed up a few other leaks, but I'm a perfectionist and it's pissing me off.
It's debatable whether or not it's affecting output. This is a really small enclosure (.22 cu ft.) so even that little woofer (Image Dynamics ID8, 0.2 - 0.4 cu ft. sealed) is really loading the Hell out of it.
While I'm screwing with the enclosure. I had it packed with 0.3 lbs (1.5 lbs per cu ft.) of polyfill. Hard to tell by ear, but the bass sounded a little fuller and perhaps drove deeper, but on the other hand it sounded slightly muffled. Any opinions on polyfill? Perhaps I had it packed too tightly, and should have only had 1lb/cu ft. Currently running without it, bass sound a little hollow (best word I can think for it).
Build Thread
Get a small square piece of 3/4" mdf and drill a small hole in the middle of it and feed the wire from the back through it and glue it to the box, viola no more air leak.
If the terminal extends past the wood inside the box, just use a hole drill and bore it out till it fits the side of the box with no gaps.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Is the cup removable? I'd remove it and goop the hell out of the back with clear silicone and then reinstall it. Put some silicone around the cup's lip while you're at it so that is for sure sealed too.
  • Who's Online   0 Members, 0 Anonymous, 1241 Guests (See full list)
