High Output liquid cooled alternator???
i would keep the stock alt and upgrade to that 180 amper. then add a second if you need more. i bet a bank of super caps in the back would hold your voltage plenty high for your liking in addition to a battery in stock location.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Thanks yeah that's what I'll do, get the 180A and a group 95R + group 48 AGM and take it from there.
@Bump4life, I looked up the price for some Maxwell boostcaps and I guess if the ends justify the means it's worth the expense but the 2k Farad caps are like $50 each? And I'd need 5 in series to give me 13.5V. More info on your cap bank?
When I hear music, I fear no danger. I am invulnerable. I see no foe. I am related to the earliest times, and to the latest.
~Henry David Thoreau
  • 3 months later...
Without knowledge of cap banks it would be best to have someone else build it for you.
You would actually want 15-16v capacity on the caps.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
replacing with a different alternator is difficult because there is a whole housing cast into the engine block. i would imagine upgrading the internals would be possible if cooling capacity goes way up, though.
Cables and wires almost never fail; the terminations do.
Just be careful about running higher RPM's. I dont know why but i've not had any luck with custom alternators holding together above 5500rpm. My singer unit blew up twice, mike replaced the rotor once and the second time I just had a local shop fix it.. but I havent put it back in since the second time either yet. The shop also put together a custom unit for me to test at higher RPM's since they were interested in what was happening and I blew that one up a couple times for them as well :)]
The stock pulley does help (took 7500rpm to knock out with large pulley) but you lose the low RPM output..
My singers been fine loaded down at 7500rpm. And I hit 7k frequently cuz VTEC.
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
Maybe its just the 270's and/or a part common to the 270 and the test alternator I was running?
Hammerdown... 1%
my singer has seen 6k a few times too... oops
  • Who's Online   0 Members, 0 Anonymous, 3140 Guests (See full list)
