Good voltage...but it drops low!
I have a problem with my voltage dropping WAY to low of bass notes. My voltage is good, hovering around 14.8-15.1 but when the bass notes hit at high volume I'm dropping down to 10.8-11.3v on certain notes. This is what I have and done so far...
(2) JLHD 600/4
(2) JLHD 1200/1
(2) 13.5 W7 in sealed box
Alpine DVA 800
Alpine PXA 800
H.O. Alt w/adj regulator 230 amp maybe 180 or so at idle...haven't had it measure
Two 0gauge per leads ran front to back to aluminum bus bar for all amps
Two 0gAuge grounds in rear. One connected to seat belt post under seat. The other to rear right quarter panel
I have also done the big 3 with clean connections
At this point I'm at a loss what to do or how to fix the issue. I'm going to try to change my ground connections to the frame of the car but that will entail cutting a hole in the trunk.
Just wondering if this great resource of knowledge will yield me any help for results.
check grounds and what battery do you have?
loganberry, on 17 October 2009 - 11:39 PM, said:
on the lows it sounds like a 90 year old vagina flapping in the wind
JayP, on 10 June 2010 - 4:53 AM, said:
Your truck looks like a prostitute gave the car a blow job with starburst in it's mouth.
grounds may not be good.
what brand alternator?
only 1 battery?
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
if you only have the stock batt under the hood than you don't have enough amperage. you really don't have any buffer between your system and the alt so it is pulling everything it can from that alt. that brand alt is it?
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
You need more capacity. Its sucking up what little power you have stored real quick. You got the the power source ( alt) You got the wire upgraded to prevent voltage drop, but your your missing capacity. You need to have reserved or stored power. More batteries.
"Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21
PIONEER DEH-P8400BH
2 CROSSFIRE C5 1700D
2 CROSSFIRE C7 18
HOOD. NSB GROUP48 TRUNK SMS AGM400
DUAL RUNS X SCORP 1/0 OFC
275A SINGER ALT.
DYNAMAT XTREME
SOUNDSTREAM TA4.280
PIONEER COMPONENTS
what kind of alt? I would take a guess and say either your alt isn't doing what you think or you have connection problems
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
op- when you say the alt hasn't been tested leads me to believe that may be the issue as alternator manufactures should supply accurate spec sheets with their product... beyond that check all connections (sounds like you got this handled). if the issue still persists a larger batt bank or a cap bank wouldn't hurt.
Those JL amps put out some awesome power, your amps alone are probably pulling 250-300 amps at full tilt and your car still pulls it own amperage after that so you're asking a 230 amp alt and those batteries to supply in the range of 350 amps. The alt wouldn't keep up with that at 3,000rpm. I would put a D3100 in the trunk and start there, no matter what batteries will only keep you in the 12's but it will be a good start and much safer for your vehicle.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
  • Who's Online   0 Members, 0 Anonymous, 7073 Guests (See full list)
