Fuse size on big three
Im doing the big three on my truck and i was wondering if a 200a fuse was good enough... For now i only have a 750 watt amp but i should be getting a aq2200 in the next few months.. I have a stock alternator and stock truck battery
I may not be the best candidate to go first...but I'd do a 300...at least that's what I"m gonna be doing for mine... :-/
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
Fuse to the size of the wiring. That's always the ONLY correct answer. You want the fuse to blow before the wire melts down or starts a fire.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
300a fuse would do you no good.
Wire for the amperage of your alt, then fuse for the wire
I have a 150a alt stock, so I used 4 gauge OFC for my Big 3 and used a 150a fuse
no fuse
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
I dont use any db reducers or resistance adders on my big 24 but thats just me
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
No point in fusing the charging wire IMO, if the factory didn't fuse the stock, then why bother, just run the wire correctly, away from anything that can pinch/cut it, preferably along the stock charging wire.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
  • Who's Online   0 Members, 0 Anonymous, 7073 Guests (See full list)
